The traveler on my G-Cat uses a standard cam cleat bolted to a bracket that is riveted with stainless rivets to the rear beam. The boat is 39 years old, and the rivets are finally getting loose. I don't have a rivet gun that will pull stainless rivets, but I could tap the holes and use quarter inch machine screws. I have the tap and the bolts; I could even go all the way through the beam and back it with nuts and washers, but I hate to add more holes. The cam cleat does not appear to be heavily loaded, after all I can easily adjust the traveler with the mainsheet heavily loaded. So, should I take the easy way out and do it with what I have or go find a rivet gun powerful enough to pull stainless rivets?
Bill Townsend
Sarasota
