Posted: Aug 09, 2022 - 05:45 AM
We have both. They are the same draft, use the same rudder blades, probably a typo on sailboat data.
They are virtually the same effort to right. In lighter wind, I need a bag. At about 20mph, as long as you get the mast upwind, (normally that’s how they drift), I can plank my 172lb out, & wind on the tramp will bring it up.
Your athletic ability, age, predominant wind, & mostly, sailing ability determines the best fit.
The 5.0 is slightly under canvassed in light winds, they really come to life in 15+
It is surprising the speed difference in light winds.
If your area sees mostly 10-15+, AND you mostly sail solo, MAYBE the 5.0 is the better choice, & would be for sure if you are limited ability and/or physical shape.
Personally, if I could only have one, it would hands down be the N5.7. Get a righting bag, & If solo, on bigger days, don’t gybe. Stretch the sails, & travel out to depower. Bring a buddy, either is very easy to right with two, even if the 2nd is a skinny kid.
Either one, the best upgrade is a furling jib.
Edited by Edchris177 on Aug 09, 2022 - 05:58 AM.
