Posted: Dec 08, 2022 - 12:51 PM
Hey Scott - no doubt; and, if you need some help vacuum bagging it and finishing in clear, just let me know since I got that down pat. We just need a good Friday evening to lay up and Saturday to do the hot coats.
I just WANT to try my hand at making a full on, vacuum infusion rudder mold, and will likely either start with the standard Hobie rudder or Prindle rudder, since those seem to be the most useful to friends/acquaintances.
The advantage of molding, is I won't have NEAR the post finish work to do. All the strength will be in the glass and reinforcements - not derived from the fill material. That core material referred to above is Coremat Xi. I did find "foaming epoxy", which looks to be the trick; hard as a rock when cured but can be poured and utilized like urethane foam. Only, it's a bit heavier and a WHOLE LOT more expensive. It may all be for nothing, but that and my giant CNC plotter are my "winter projects". Once I get going, I'll post.
Chuck C
NACRA 500 Mk2
Hobie 21se (sold)
