Water in the fiberglass can not be pressed out as someone suggests
If you suspect water in the fiberglass it can only be detected by weighting the hulls/boat.
Note the Tiger is built with a foredeck that is glued to the hull, so this indicates a small amount of water between hull and deck.
Unless it leaks water into the hull the problem is miniscule.
The worst that can happen is that you have pry off the lid and reglue it. It can be made in a few hours.
NO RED flag, as this is not within the bearing structure of the hull!
This the center deck plate, the foredeck plate is a lot simpler:
Edited by revintage on Nov 21, 2022 - 06:07 AM.
Brgds
Lars
Frankentri 5.8/5.5/Inter20
Aerow trimaran foiler
