Thank your friends with a C2 or Akurra as Goodall put together a nice video a few years ago that is a good primer on trailing edge repair.
https://www.youtube.com/watch?v=dIe7kMKuKfA
I've used this method on a pair of 12yr old C2 boards with success and they're still winning regattas. A few things I've learned over the years:
1) Use epoxy rather than polyester resin. It's about 2x stronger. West System is the standard.
2) Be very careful on the epoxy ratios. It won't cure to full strength if you're off by more than 5-10%
3) You need to maximize solid surface area for a good bond. That means you need to be fairly aggressive with the length of the V shape. The rise:run rule of thumb for scarf repairs is 12:1 I think. In one case my repair was asymmetric (ground more on one side than the other) to keep the scarf angle as shallow as possible without running into the white gelcoat.
4) Be careful of epoxy/cloth ratio and that you properly saturate each layer of fabric. CF is much stronger than the epoxy, but it needs the epoxy as the binder.
5) I used some pieces of plexiglass for my formers with lots of spring clamps.
6) I use wax paper as the release paper
7) I was lazy and got the CF cloth on Amazon. There are many other sources.
Best of luck. Don't be afraid to try. I was nervous at first, but even if you mess up you can grind it out and try again.
Jeff R
'88 H18 "Jolly Mon"
'10 C2 USA1193
NE IN / SE MI
cramsailing.com--
