I recently got a Nacra 5.5. It was missing the main halyard when I got it. It has a hook at the top of the mast, and I'm wondering if anyone has recommendations on which of the halyard rings sold by Murray's would work best with the Nacra 5.5. I'm planning to use about 60 feet of 3/16 rope for the halyard instead of the rope/wire halyard that I believe was original. Are there any other parts needed or issues with using an all rope halyard?
I had trouble releasing the halyard on my Nacra. I finally figured out that the ring it came with was too large and even rotating the mast as far as I was physically able, the ring still sometimes wouldn't clear the hook. I got a smaller ring (one with the eye proved unnecessary) and problem solved. Don't forget you're going to need a twist shackle to attach the ring to the mast head.
The one with integrated shackle is better in my experience, it rotates more consistently. This one works well for me, you just have to remember which which side is the hook, it’s where the bigger section of the ring should go. https://www.murrays.com/product/01-4216/
I guess the aussie ring - the symetrical one- will work fine too. The way you tie it is important, because it gives the ring a different angle of attach to catch the hook. You may use a stopper knot pointing forward or aft, or as in my case a bowline which will keep it vertical. Stopper knot is more common, i don’t remember which side.
Yes, that's probably best. If you already have the parts and wanted to cheap out, use just the ring and two "D" shackles will get you there. Like I said, the diameter of the ring will have a lot to do with the ease of getting the ring away from the hook when you rotate the mast. When tying onto the ring you want the shortest knot possible. If that's an issue, try one half hitch around the ring and use a stop knot (not a figure eight) on the very end.
This will be the most frustrating thing in the world. Depending on how they mounted the hook will determine which ring works best. I have never used the one mentioned previously, but of the 4-5 halyard rings I have, I prefer the "Aussie Ring" https://www.murrays.com/product/07-3064/. And, how you tie the halyard dictates how it hooks. This is something you have to experiment with. On the Tornado, I have 1/4" double braid and spliced it onto the loop. On the modified 18-2, I have a 3/16" XLS tied with a bowline. My P19 liked to have a knot facing aft. I know some boats like the knot facing forward. Where the main halyard grommet is will also dictate how it attached. I would recommend hoisting the main. Flipping the boat over and then spend about 30-45 minutes trying different rings and/or different attachments. If the knot has a particular way of going, write that on the mast so you or your crew remembers. Nothing like hoisting the main 4-5 times to only realize the knot was the wrong way.
Before you start raising the main, clean the sail track of the mast real well first and then spray SailKote of something similar. Also, as sails age, the bolt rope shrinks. You'll see a lot of wrinkles at the bottom of the bolt rope with some hand stitching holding it in place. Cut the stitching loose. The bolt rope will suck inside the luff tape probably 4-6" (depending on age). This will give the sail a "face lift" and get rid of the wrinkles.
I would also add a block under the mast for the main halyard redirection. The older boats have the halyard running outside an exit where you have to pull down to raise the main. With the bottom block, you can stand at the aft beam or even sit on the trampoline to raise the main.
-- Scott
Prindle Fleet 2
TCDYC
Prindle 19 "Mr. Wiggly"
Nacra 5.8 "De ja vu"
Nacra 5.8
Tornadoes (Reg White) --
About the halyard, you don’t need the rope/wire type, that’s a different system with a lock at the front of the mast. Get a decent line, a cheap one will stretch and make things much harder, especially pulling to release the ring and lower the sail. Even worse when you do that on the water, not common but you might find yourslef in that situation. i use a dyneema halyard, not ideal because it’s slippery, but got it at a good price. I wear gloves and use an easy rig tool on the last part, it helps a lot and protects yogur hands.
You can find 5.5 Nacra assembly manuals on line.
I had a 5.5 for a long time. Ring with separate twisted shackle worked best. Just like the manual shows.
https://www.nacrasailing.com/wp-content/uploads/2019/08/nacra-vintage-assembly-manual.pdf
I would not use dyneema because of the poor knot retention. Remember all the downhaul load will be on the hook, ring and twist shackle. The mast rotating back and forth could loosen a dyneema knot that has no static load on it. If you still insist on using it, tie it off in a way that leaves some tension on it.
Thanks for everyone's replies. I got the Murray's main halyard ring, and I got the mast up and have the boat at my local sailing club. I am slowly figuring out how everything is rigged. I was going to sail it this weekend, but the wind was a bit stronger than I felt comfortable with for a boat that I'm unfamiliar with. I appreciate all of the suggestions, and I will do some experimenting to see what works bet.
