Hobie 16 Transom
I just picked up an old H16, the transom was a bit distorted, looking on line it seemed tbe cause would be wet and swollen timber in the transom. I took to it with tbe multi tool and sure enough it was wet swollen and soft. I got to the alloy plate and stopped. I’m assuming there is no timber on tbe otber side of the alloy plate ?
Correct. The aluminum plate (tapped for the gudgeon screws) is the farthest inside layer of the transom construction.
Clinton, Mississippi
nzhobie 123I’m assuming there is no timber on the other side of the alloy plate ?
So:
1. See where the water is coming in and plug that, unless it's through the transom, then see #2.
2. You talk to someone who knows catamarans (especially Hobie 16s) and fiberglass, and can tell you how to rebuild it. The transom translates a lot of force to the entire boat, and deserves your respect.
