I bought a Nacra 5.2. It is my first cat and am cleaning it up. However, another member at the club pointed out that the mast is from 5.0 and not 5.2. Seller had been sailing it per his report. So, my questions are
1. is it ok to sail 5.2 with a 5.0 mast? I guess if the seller was sailing it should be fine but I know very little about the cats.
2. Mast base has one lip and not two. I will post a picture as well It looks as if one lip from the casting has broken off. Is that a concern apart from cosmetic?
3. I want to change the shrouds and the forestay just to be on the safe side. They look ok apart from one or two frayed wires and a bit of rust but don't mind just changing them. Shrouds were 19ft long and were attached to hull through 2 shroud adjusters daisy chained instead of one. Forestay is 18ft 7". So, do I buy the 5.2 shrouds and forestay or since it is a 5.0 mast, should I buy them for 5.0
It had a little booboo on one of the hulls and I managed to repair that with fiberglass and epoxy.
Hoping to buy a righting line too - will any 0.5" deck line do?
Thanks and sorry for the assortment of questions.
