This is the time of year we should going over our boats with a fine tooth comb looking for things that could possibly fail and ruin our day. But for some, the condition of the trailer is often overlooked and certainly carries the potential to ruin things as well. Springs, axles and U-bolts are obvious, wheel bearings aren't and the amount and type of usage should dictate how often you need to re-pack them. Their condition when you do re-pack them should give you an idea of how often this is needed. Don't rely on "Buddy Bearings" or their knockoffs. They may increase the interval but aren't a substitute for proper maintenance. One thing that does help however, is if your launching situation is where you don't have to submerge the hubs when launching. If you're uncertain about any of this, just get out and touch the hubs after going 50 mph. If they're hot, you'll know what to do. Another thing that might get overlooked is lug bolts. Don't get stuck because you're unable to change the wheel. Loosen the lug nuts every season and grease the bolts. Here's one thing that I overlooked, and that is where the yoke is bolted to the trailer tongue. On mine, the yoke is welded to a plate which is bolted to the trailer tongue. I saw a little rusty water gathering around that area. One might assume there should be a drain hole under there. I took the yoke off and turned it upside down and at least a pint of rusty water poured out of it. After it dried, I banged on it with a hammer and large chunks of rust fell out. There was a drain hole all right, but it was completely plugged.
Bill Townsend
Sarasota
