Do you take your mast apart when trailering? My trailer has a mast rest, and so far, I've left the mast together, put it on the rest, and then balanced the back end on the rear crossbeam, then bungee both ends down. When driving, it only hangs about 2-3 feet off the back of the cat. Keep in mind that on my cat, both parts of the mast are aluminum. Another thing to keep in mind is that the halyard line runs inside the mast (in the same channel the sail rises up inside), so I'm not quite sure how taking the mast apart would affect the halyard itself.
Is there any danger in leaving the mast in one piece while traveling? If you take it apart, how do you then use the mast rest?
I'd like to thank everyone who's been taking the time to answer my newbie questions. You guys have been great.
