Posted: Sep 03, 2024 - 09:08 AM
Alignment is inconsequential if you sail with one rudder up. If you determine you still have too much weather helm on the port tack, lessen the rudder rake on your starboard rudder. If the rudder is already raked as forward as it will go, you may have to lessen your mast rake and then work on the rudder rake again. Under no circumstances should the mast be forward of plumb. I once had a boat that had the same problem and I couldn’t fix it doing what I just described. I later discovered that one of the hulls was toed out a half inch from center line. It’s very unlikely that’s your problem, but if it is, good luck!
Bill Townsend
Sarasota
