I've had 3 SC20s and have yet to see a single video or hear from someone that has actually righted a 20 using the righting system.
Would love to hear from anyone regarding this challenging process.
I added hyfield levers to my Stiletto 27 after consulting with Tom Haberman @ ARC. I have never had to use the levers solo but for practice I used the main halyard to pull the boat over in shallow water to test the righting process.
You only have to do the upper lever. As mentioned above, pull the pin and activate the lever to release the stay tension on the upper shroud. My boat was well balanced at this point and just a little weight on the end of the centerboard righted her very quickly. I have righted H16s and H18s hundreds of times. Righting a 1200lb 27 foot beach cat using hyfield levers was easier.
I have seen a video of a Dragonfly getting righted using hyfield levers as well as a Gougeon 32. I will try to find them.
They are like magic. Righted a Hobie 21 with them. But the extension cable broke. That was my fault for using to thin a wire for the extension. Had a rigger make me some dyneema shroud extensions.
How the heck do you reach the lever. If the boat is on its side you can’t reach the shroud from the bottom hull. Not even on an 8ft wide boat. If you try and climb the tramp you are going to pull the boat full turtle.
