Thanks Dannyski for your reply on the H18, The head of the mast does have a foam bung, i am more worried about when the FISHER_MAN is not there to Help me lift the mast,, i was thinking of putting a mast float on,Do you know of any problems with doing this. Hobie sell's a mast float that displaces 60 pounds of water, Called A ''Hobie Bob'' would this do the job or cause more problems, I am also struggling with the idea that the foam in the top of the mast gives the mast more buoyancy -if the mast was sealed tight and water could not enter,how can it give more buoyancy, ,, a sealed drum will float better than one that is filled with foam, as it does not have the extra weight of the foam, i think that the foam in the mast was only put there as a precaution for Mast's that took water later on in life. i would like to here your thoughts on this and the mast float,Regardless of this , i am glad i bought the H18, she's a goog looking boat, Cannot Wait To Get her out on the Water, The winds howling at the Moment,, pepsi.
edited by: pepsi, Oct 15, 2008 - 10:25 PM
