Has anyone replaced the rear traveler on a P18, and if so can you offer a little guidance?
Must I remove the rear crossbar end cap, rivets and all?
Thank You
The traveler car is easy to replace, just drill out the rivets in the end cap and remove the end cap. The car will come right off. When you replace the end cap you can either rivet or use some SS screws. If you plan on keeping the boat for awhile buy the best replacement car Murray's has to offer.
When drilling the rivets out, do I replace with stainless steel or aluminum rivets?
Where is the best place to buy a rivet gun and rivets for this type project, as I'm sure there are different types for each application??
Thank You All!
Not positive on the type but my guess is aluminum since its not structural (you will know for sure if they drill out easy). If aluminums the case a simple hand rivet tool will do the trick, about 20 bucks in a good hardware store. For the SS rivets I bought a pneumatic tool.
