Ive been sailing a Prindle 19 for years, and now I own a Nacra 20, but going downwind with spi, I capzised 4 times. Can anyone tell me how to do the downwind leg?
Marcelo,
You will love the 20. It is a great boat. You want to sail deep and sheet tension should be enough that the luff is just on the edge of breaking, or curling. It combines driving the boat deep and sheet tension on the spin. Don't oversheet the spin, if you get hit with a gust, drive down. Make sure to keep mainsheet tension on. This acts as the backstay for the mast and will prevent it from breaking.
i agree.. sail VERY deep until you get a feel for it. Make sure you have enough luff tension on the spin.... be warned everything is opposite with a spin... Head DOWN to depower.. sheeting out creates speed in most cases.
Try 5-8 mph wind to start. It took me a dozen times to get a feel for the spin.
Main downhaul is usefull and lift your dagger boards 1/2 way up... this helps sometimes
Same as bear away or falling off. http://www.scils.rutgers.edu/~elfox/terms.html
Terms heard directed to crew in extreme conditions.
"Dump It, Dump it NOW" followed by "hang on no matter what" usually when overstanding the leeward mark or
"heat it up" when trying to fly a hull to reduce windward hull drag.
