re: [beachcats] p-16 rudder kick up - help!
Had an 18' P. The springs are worn and or stretched.
Temp. you can compress them with a pair of channel
locks, but this won't last long. Either cut one loop
off and remount them, or buy new ones.
--- "J. Scot Mackeil CBET" <jsmackeil@yahoo.com>
wrote:
> P-16 rudder kick up - HELP!
> the rudders on my p-16 often kick up unexpectedly.
> any veteran p-16 guys have any advice on improving
> the function of these rudders?
> fair winds, J. Scot Mackeil CBET Jordan Hospital,
> Plymouth Ma.
> office: 508 830 2524, M-F/9-5, fax: 508 830 2661
> www.jordanhospital.org, 275 sandwich st. plymouth
> ma. 02360
> learn more about plymouth kayak paddlers click here
> Don't let your dream ride pass you by. Make it a
> reality with Yahoo! Autos.
> [Non-text portions of this message have been
> removed]
____________________________________________________________________________________
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
Group Home
http://www.TheBeachcats.com
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/beachcats/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/beachcats/join
(Yahoo! ID required)
<*> To change settings via email:
mailto:beachcats-digest@yahoogroups.com
mailto:beachcats-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
beachcats-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
I have a P-16 that suffers the same problem, but only on one side. There are two parts on the rudder we need to be concerned about here. Lets call the one the catch, its the spring loaded bar in the rudder frame and the other the hook, which is the part attached to the rudder blade. The solution is to adjust the hook that is attached to the rudder blade itself. These are held in place with two nuts, one inside the hole in the rudder blade while the other is outside. Sometimes these nuts come loose allowing the hook to move. I solved the problem by loosening the nuts, turning the hook clockwise several turns then retightening the nuts. This had the effect of pulling the rudder closer into the rudder frame thus changing the angle between the catch and the hook. Its a tough fix at the beach, try it while the boat is on the trailer. This should solve your problem.
