The Hobie 18 is simple to take apart, just remove the 8 bolts, two at each corner from underneath the deck lip.
The only warning I can think of is to make sure the hulls are supported (both sides) if you are taking it apart whill on the trailer, you don't want the hulls falling over and being damaged.
If possible, take some pictures as you do this, it would be great to have step-by-step pictures in the "Beachcats Technical" section for the next H18 owner who does this.
How To Create Your Signature
How To Display Pictures In The Forums.--
