Moving up to an 18
I am a member of the Hobie fleet in Memphis, TN. I have been sailing a 16 for several years now. I have an opportunity to move up to an 18 with wings... How much more is involved with sailing one of these. Can it be set up by one person? I have been out on Damon's boat once, but I was under his "wing" and did not help set it up...
Hey streetdoc432,
My unbiased opinion is that you will love a Hobie 18 with wings!
There a few differences I can think of on setup. On the 18 you'll have these additional items .vs the 16:
  • Mast is heavier, but not too heavy for you to raise.
  • Daggerboards, just take a minute to attach
  • Zipppered roller jib, means you attach a temporary jib halyard extension while raising the jib.
  • With wings you may not need the trap lines, saving that setup.
  • Unfolding the wings and attaching the pins takes a few minutes, unless you go with toggle pin$.
That's all I can think of, most things are the same, like the rudder system, lacing a tramp, raising the main. The whole boat is quite a bit heavier than your 16, so a good set of Cat Trax will make life easier. But when keeping the boat mast-up on the trailer at Delta Sailing Association you don't have to worry about that.
How To Create Your Signature
Hello Streetdoc... You will love the 18. I'v sailed 16's for many years and upgraded to a 17 with a super jib~I call it my 'Hemi'..Good fast boat for 1-2 people(depending on weight,seats can only hold 350lb.) Then and friend of mine sold me his 18 mag..It's like a ''Caddy'' I love both boats, and won't go back to a 16... Put trap wire's on the 18~~ You'll want them when it's windy....Settin up ain't much difference than a 16, but a little heavyer.. You should have another person when ya set it up..After ya raise the mast & hold it in place~~ they can attch the roller furl. & help ya with other stuff ETC ETC.... Now go get that 18 & have fun and sail SAFE & WET~~~>>> you'll have many of these~ icon_biggrin
and other toys.......
Bernhards Bay. ~~~~~~
I'll never go back to a 16, except to play. The 18 is much more stable and points higher. I had water over the leeward hull up to the forward cross-bar, and it blew right through without slowing much. I solo it often, yet my fastest speeds were with two of us trapped out. Even in 25 kt wind, I could make it go while solo. You won't regret it.
