maximum speed from minimum wind
17 Users
12.3 K Views
(@ncmbm)
[#18550]
What are your best go fast techniques for light wind? How do you prep the boat? Wax it or sand it? how about the daggers and rudders. Keep windward dagger and rudder up? Give me all the secrets for going fast in a lake. Thanks
Posted : September 25, 2006 1:37 pm
(@mauganh17)
move around gently and gracefully on the boat if you have to move at all. Maintain as much momentum as you can, be light on the tiller. Get forward and get the sterns out of the water.
Don't worry too much about hull prep.
Posted : September 25, 2006 2:34 pm
(@rhino1302)
Around here if the wind is light it's very shifty. Being in the right wind (and trimmed for that wind) is far more important than boat set-up. I find that just reacting quickly to a wind shift will often get you a few boat lengths on the competition.
I rarely raise a board in light air. I figure that when you are going slow you need all the lift you can get. Also if you are constantly changing points of sail, the disruption from moving about and futzing with the board will cancel out the decrease in drag. I don't raise a rudder either.
MauganN20's points about getting your weight forward, not disturbing the boat by moving about and being light on the helm are also very important.
Finally, to compete well in light air you have to practice in light air. Not many people have the patience to do that. But those that do are almost always at the front of the pack when the wind shuts off, dispite all the griping about
unfair conditions
Posted : September 25, 2006 3:23 pm
(@wouter)
Rather flat sails are fast. Sails can easily be too full and actually hurt your speed while you are thinking that full is good because you need all the power you can get. So don't do that. Keep speed up any way you can. If you drop of the groove and loose apparent wind then you have to accellerate up all over again and that is slow.
Wouter
Posted : September 25, 2006 4:43 pm
(@stitus)
All of the previous comments are good.
When going upwind, we get the crew forward onto the leeward hull while I sit in the middle to make every attempt to get the windward hull out of the water. It's amazing how little wind it talks to lift the hull and how much lift and speed you can gain when this happens.
Downwind we each get out on a hull and get the sterns out of the water. Keeping the boat moving is paramount. If you stall, getting going again is brutal, but I've also found that you can go a bit deeper as the apparent wind isn't very far forward.
One other trick: When jibing, give the mainsail a big pump when it comes over to snap the battens over and push the boat back up to speed. The same goes for tacking, but roll the boat as much as possible, then yank the boom or sheets to snap the battens and give the boat a boost.
Posted : September 25, 2006 5:07 pm
 Trey
(@NCSUtrey)
From my training session with Olympic sailor Robbie Daniels, he told me that he never saw an advantage to the crew going to the leeward hull in light air. Stay forward on the boat and maybe a little central, yes, but I don't see any advantage in sending crew to the leeward hull.
Posted : September 25, 2006 5:53 pm
(@catman)
In very light-flat conditions a boat that weighs a little more can have an advantage. Once you have the boat moving it won't slow down in the lulls as fast as a lighter boat.
Lay down, keep as flat on the tramp or hull as possible. Look at your boat and find things to make smaller to reduce windage,drag.
So bring the case of beer and ice, keep your head down and have fun.
Posted : September 25, 2006 6:03 pm
(@stitus)
Quote
Maybe you misunderstood what he was trying to teach you. Try it sometime. If you can help the windward hull out of the water, you will be faster.
Posted : September 25, 2006 6:05 pm
(@rhino1302)
Even if you can't get the windward hull out of the water you still need to get those sterns out of the water, and the logistics seem to work out best with the crew on the leward bow and the skipper just forward of the crossbar on the windward hull.
Posted : September 25, 2006 6:21 pm
(@stitus)
Quote
I should be more specific when I say that the skipper sits
in the middle.
I usually sit on, or as close to the front crossbar as possible and as close to the mast as possible. Getting the sterns up is key. My crew weighs 175 pounds and can easily get the sterns clear with me on the crossbar.
Posted : September 25, 2006 6:27 pm
(@Anonymous 38749)
I agree with previous. I have never noticed an advantage in light air in trying to lift hull. Makes it harder to judge the boat and draws energy and concentration from what matters.
Wouter is right. Flat sails work better.
DO NOT OVER SHEET TRYING TO GRAB WIND>you will stop.
Steady quiet movement if at all. sit on cross bar and get the sterns out of water.
Decide on these tactics before the race and DONT change them.. the wrong choice will work better than trying three different things and being right for a third of the race.. stay quiet and win.
Watch wind carefully, don't get lazy and board with that.
Recently I caught a breeze because I was watching and waiting.... the lightest rise in pressure. The boat right on my tail who had gotten board got home an hour later because that little puff was the bridge to a lift which he didn't make.
If the crew on another boat moves about and slows once when you do not you WILL pull away, so do not leap to follow anothers moves. Sail your own race. IF you are neck and neck with another do not change about boat unless your tactical decision is very certain and know the change WILL cost you and you have to make a strong advantage to make the risk worth it. If you make a move be VERY steady in it and hopefully the other crew will be rougher when following you and that will make a gain for you.
Somehow decide that this form of racing is as intersting as bashing through a chop. Don't listen to others who say it was 'anybodys" day. They just don't have what it takes.
Posted : September 25, 2006 7:08 pm
(@_removed-account)
Four Star Admiral Registered
Invest in a Squaretop. The extra area up top made a BIG difference on my 17.
Doug
Posted : September 25, 2006 7:25 pm
Chris
(@greencj)
On modern boats (e.g. F18 or N20) a bunch of downhaul to open up the top of the sail and allow more sheet tension that running minimal downhaul is faster in the really light stuff. (Flat sails - like Wouter said).
Plus what has already been said - weight up front, move gently, be smooth, keep in the groove, don't give up.
Another good move is to watch the puffs coming down the lake carefully and get in the right place at the right time, and when going down wind, if you are in a puff, gybe to stay in it.
Chris.
Posted : September 25, 2006 8:21 pm
(@wouter)
That is what I'm finding as well. Both crew on opposite hulls and far forward.
That spi pole makes for a nice foot rest.
wouter
Posted : September 26, 2006 1:40 am
 Trey
(@NCSUtrey)
Robbie was quite clear in telling us that sending crew leeward in light wind was pointless when going upwind. I'm not going to argue with him...his record is much better than mine, and most everyone else here as well.
Posted : September 26, 2006 6:38 am
(@Anonymous 13024)
There are grades of light wind, and this might differ from boat to boat and different windspeeds. If you are in doubt, arrange for a boat to follow behind you and look at your transoms. You definately want the water to exit both transoms cleanly. On the Tornado in the really light stuff, crew is sent to lee bow. If both sit on the same hull, the transom will dig in.
Posted : September 26, 2006 6:56 am
(@wouter)
That maybe so, but I still do prefer to have the crew at the leeward bow manhandling the jib or holding the mast rotation firm. This way the crew is also out of my way (and the tiller/mainsheet I'm holding) and is still capable of adjusting the trim of the rig when need be (something he can not do when he is ahead of me on the luff hull).
I see therefor many points of reason to having the crew on the leeward hull. The only downside is can't do roll tacking very well like that. On the other hand, in some really difficult conditions I have also remained in my spot after a tack/gybe and continued sailing like that. Sure makes
NOT rocking the boat about
alot easier to accomplish. You can get really smooth tacks that way.
Maybe it makes Robbie slower to having a crew on the leeward hull but it certainly makes ME faster and that is why I do it.
Wouter
Posted : September 26, 2006 7:09 am
 robi
(@robi)
So flatter sails in light wind using downhaul is fast?
Same applies in a windier conditions? So the downhaul should barely be slacked at all?
I am kinda confused now.
Posted : September 26, 2006 7:10 am
(@wouter)
A crude summary.
Really light stuff : downhaul on
medium winds : downhaul more loose
heavy winds : downhaul back on again.
Wouter
Posted : September 26, 2006 7:14 am
alutz
(@alutz)
It is importand that the boat stays calm, to keep the flow attached to the sails. No slapping in the waves. Every movement of the sails and the mast hurts. Our 18HT is very sensitive to movements due it's light weight and the tall mast.
I found for my self, that when there is a small ground swell running, the boat stays much calmer when we are sailing on one hull. We do everything to stay on one hull when the boat shakes. We sometimes even trapeze to leeward to avoid the nerve breaking slaping of the windward hull.
I also read in some A-Cat go fast manual, that the drag is increased by 10% when sailing on two hulls. I don't know if thats true or not.
When there are no waves and maybe some small puffs, I agree that it is faster having both on the windward side. It's not good when the crew has to climb up to the other upper side, to keep the boat down.
Of course, the stern MUST be allways out of the water.
Keep your eyes on the mainsail lech tell tales. They should fly for around halve the time. Over sheeting is very slow.
Posted : September 26, 2006 7:18 am
(@terryback)
At Wildcat I was using 7.5 of 10 (relative scale) going to wind and no downhaul to C mark with spi'.
Sunday, practicing with no wind, I was pulled in really tight 8-9 of 10 ... of course, I couldn't test it as we abandoned the races due to light winds.
Posted : September 26, 2006 7:20 am
 robi
(@robi)
Quote
That makes total sense. I was barely pulling on my downhaul. The speed differences were definatley noticeable. <img src=
Good info TBack. I going to need help to mark my mast. I noticed you had marks. Good thing we are having our FREE SAILING clinic for whoever wants to show up at Lake Jackson FL on OCT 7 and 8. (shameless plug!) <img src=
Posted : September 26, 2006 8:10 am
(@Anonymous 39155)
Quieter is faster. On Sunday, Tback and I were testing settings and I noticed the boat was faster and quieter when I moved forward. In my case, this was just in front of the shroud.
<img src=
/> Pay attention! If you miss a shift in light air you'll be in irons all day. Trust me on this!
Posted : September 26, 2006 8:14 am
scooby_simon
(@simonJlongstaff)
My opinion, upwind only.
Crew positions
1, Light wind and no real waves, crew to leeward hull to help lift the windward one and get well forward
2, Lightwind and some waves that are shaking the rig around, crew leeward side of the mast and as far forward as possible
Downhaul
1, Light wind it is on fairly tight
2, As soon as you start to make
proper
progress and there is a bowwave forming id consider taking it off as it this point you may have enough wind to keep the air attached to the sail(s)
3, As soon as the hulls start to get some lift I would have the DH off fully (even the odd crease in the sail att the bottom)
4, as soon as overpowered, bring the DH on again.
Mast rotation
1, very light I'll de-rotate a little to keep the sails flat
2, light (but
proper
progress) max rotation.
3, As soon as nearly powered up I rotate to the shrouds
Posted : September 26, 2006 8:27 am
(@flatlander)
Quote
What are your best go fast techniques for light wind? Give me all the secrets for going fast in a lake. Thanks
A Hobie 18 with an SX mast and Tiger Main, right?
I'll agree with Steve and Andi on the get the hull out of the water (although may not happen until upper end of light winds). The boat stays calmer, sail more efficient. The boat's shorter than the T or N20.
Inland lakes can have a lot of chop (damned powerboats) and in our experience a stock Hobie 18 needed some power to help drive through the chop (very flat didn't work). I can't speak to the
modern
Tiger main.
All posts good advice, there will be variables.
Posted : September 26, 2006 8:53 am
(@Anonymous 76)
Quote
Robbie's mostly a T sailor? Light-air techniques vary from boat to boat just as medium- and heavy-air techniques do. My metric Nacras need to be sailed bows-down, but the 20 needs to have the leeward bow just touching the water. So it varies. Good luck.
Posted : September 26, 2006 9:11 am
(@ncmbm)
Yes, SX mast and tiger main. Running a spin as well. The tiger main really changes the way the boat feels, its hard to get used to. I've been rotating the mast more and more to get what seems to be the right shape and the tales to flow on both sides. Have tightened the diamonds to 500lbs to get some pre-bend. Think the comptip is bending too much, squaretop seems disturbed. Have installed tell tales on the lower portion of the main but as of yet not been back in the water.Thanks so much for the great advice from all. Are you all saying that boat prep is not important? Shouldn't it at least be cleaned and waxed? One last question, mast rake for light winds- what do the tigers do? Mine is back, second hole from bottom on forestay adjuster. Forward rake requires repositioning of spin pole height on my boat.
Posted : September 26, 2006 10:44 am
(@rhino1302)
Cleaning and waxing your boat may gain you a few seconds over the length of a race. If you are an excellent skipper in a highly competitive one design fleet those seconds may be critical.
In very light/shifty conditions, getting into the right wind can make a difference on the order of tens of minutes. Boat handling (sail trim, weight placement, clean mark rounding) can make a difference on the order of minutes.
That being said, a few second lead can turn into a few minute lead if you can get to the first mark before the pack does. Nothing nicer than looking back at the mark and seeing all of your competitors trying to round at the same time in virtually no wind. And there's nothing worse than having that few minute lead turn back into a few second lead as the wind fills in from behind.
Posted : September 26, 2006 11:30 am
(@wouter)
If the comtip is too bending then DON'T rotate your mast too much. Over rotations will make the top of the leech fall away too soon. Present the top of the sail with the mast stiff direction of the mast top and that is the fore-aft plane of the mast = relatively little rotation.
Wouter
Posted : September 26, 2006 12:04 pm
(@flatlander)
Before making any wholesale changes (oops, I guess you already sort of did that) I'd go with what I knew was fast from the original setup and then try individual changes. For instance, we found the fast setup w/the 18 to be no rake (2nd hole from the top), no pre-bend. The Tiger main luff will dictate your prebend.
Posted : September 26, 2006 1:10 pm
Page 1 / 2
