1979 Nacra 5.2 Rebu...
1979 Nacra 5.2 Rebuild
10 Users
18 Reactions
Cat Scratch
(@cat-scratch)
Attempting to push epoxy into such a tight crack (delamination) is gonna be fraught with near failure.
What I would do is similar to what what you did to the tip of the rudder. If you have a table saw, I would saw into the delaminated area to a bit wider than the width of the G10 (for the G10 AND thickened epoxy). Be sure to cut as deep or deeper than the delamination. A large band saw might be better yet. The multi-tool that you used for the tip repair might be ok,too, if you can saw deep enough.
Thoroughly coat the sawed surfaces and G10 with neat epoxy to provide for the best secondary bond, then fill the sawed crack with thickened epoxy (something like West Systems High Density filler or Colloidal Silica), then slide the G10 into place, allowing the excess thickened epoxy to ooze out. Be sure that the overall thickness of the rudder head at the repair is approximately the same thickness as the other good rudder's head. Use clamps very carefully. You could measure with some calipers.
Trim and finish after cure.
The other option would be to try prying apart the split rudder head enough to inject epoxy far enough down the crack to effect good enough repair. It might work, but you'd never know if the epoxy would fully fill the bottom of the crack, and therefore the crack may propagate further with a load on the rudder.
I would warm the slow-cure epoxy to lower it's viscosity and warm the rudder head as well so that there would be a better chance of capillary action helping to suck the epoxy deep into the delaminated fissures. I wouldn't use fast-cure epoxy for this method. It could get too hot during it's cure and actually harm the rudder core materials.
I think the main problem with this method is that the rudder's core and delaminated fissures likely have crud on those surfaces, so 'gluing' them together might not work well if those surfaced aren't perfectly clean. From plenty of experience in failures and successes, I'd do the first method with the G10.
Or.... if you can ensure that the fissure is perfectly clean, maybe with the help of the multi-tool and sandpaper, then prying open the fissure slightly and slathering-in a coating of neat epoxy along with thickened epoxy might be just fine and more expedient.
This post was modified 4 weeks ago 2 times by Cat Scratch
Posted : May 30, 2026 8:22 am
(@dogboy)
If that area of the rudder is solid glass (or at least reasonably thick glass skins), you might be able to inject some low-viscosity resin down into the crack and then also drill and countersink a couple holes across the width of the rudder, close to the edge.   Then install some stainless steel flat head wood/sheet metal screws.  This would give you an adhesive bond down into the crack plus mechanical clamping.
Otherwise, inject resin into the crack and the  wrap glass/carbon around the edge so that you have fibers running perpendicular to the axis of the crack
Posted : June 1, 2026 8:23 am
(@leadbetter)
Thanks for the recommendations. I'm going to sand into the crack with some nail file emery boards
and see if I can clean it up enough to go with the simple fix. The G10 project on the rudder end took some time and I am out of patients with the repairs!
Posted : June 1, 2026 4:07 pm
Cat Scratch reacted
(@leadbetter)
You talked me into the G10 repair. The inside tip of the rudder has crack that traveled farther than I thought. Hopefully this will hold for a summer!
Posted : June 2, 2026 2:31 pm
Cat Scratch reacted
Cat Scratch
(@cat-scratch)
Posted by: @leadbetter
Yup... cracks will always surprise you/me. Think they're only a couple mm deep.... Ha! Think again!
I'm fixing 'gelcoat' cracks within the Mystere 6.0's centerboard well casings.... what a pain! They're not merely gelcoat cracks. Sand-blasting is a great way of cleaning/abrading hard-to-reach areas and exposing more problems! Oh yay.
Yeah... sometimes I have to pull back and complete something else just to keep on 'keeping on.'  Hay the pastures.... sew a few more lines on the trampoline.... Work on the Sauna foundation.... continue fairing the F18 C2 hulls.... oh the list keeps growing.
Something that keeps me going on these boats..... the goal of racing them.... not only in round-the-cans races, but in long-distance races that require a robust craft. I was looking at the Texas 200 website this morning.... dreaming. That kind of thing keeps my goals in sight.
This post was modified 3 weeks ago by Cat Scratch
Posted : June 3, 2026 8:57 am
(@leadbetter)
Although its time consuming fixing things right the first time should pay off. Here is a picture of the G10 repair to the rudder head. Also looking for information on the serial number of the boat. I'm thinking its the one thousand forty seventh production model and was built in April of 1978 and TRR represents Tom Roland Racing. Does anyone know what the "C" stood for?
Posted : June 11, 2026 12:01 am
Cat Scratch reacted
Cat Scratch
(@cat-scratch)
Good looking repair job!
Posted : June 11, 2026 10:37 am
(@leadbetter)
Put some more gelcoat on the rudders and got them finished today. There are a couple of thin spots but they are very smooth and I'm finally done with gel coating and sanding. I was planning on using marine grade silicone to adhere some carpet in the top opening of the danger board slot. I don't want to use carpet glue because its probably impossible to remove. Does anyone have a better idea?
Posted : June 15, 2026 9:20 pm
Cat Scratch reacted
Cat Scratch
(@cat-scratch)
Nice looking rudders! Good repair job!
I would NOT use any form of silicone on a boat that may require repairs in the future. Silicone residue is extremely difficult to completely remove, even though you might think it's completely removed.  I would use a contact adhesive. They're not too hard to remove the adhesive residues with xylene or other types of thinners.
Posted : June 16, 2026 2:47 pm
(@leadbetter)
Used good old carpet glue. The can says its removable/clean up with acetone.
Posted : June 16, 2026 9:31 pm
Cat Scratch reacted
Page 3 / 3
