been playing with some logo's
Anyone any idea what the block is for ?
Pass a line though it with blocks on the trampoline to send it back to the sides so you can tension the line from the trapeze? Or simply for a shock cord to keep everything neat and tensioned on your tramp...
Hope; I have a seperate line tune for this. If you look at the line the rope follows, you cannot uncleat from the wire.
I would like a picture of this thing in action, because I really can't figure out what this thing is for. If you have a separate line to control the rotation, what is this for then? Is that an emergency release to be used only when you capsize? With the block linked to say the rudders so the mast rotating in the wind turns the rudders so the boat stays stable while you climb on it?
Or is it some clever arrangement of blocks to link the mast rotation to something else? I'm at a loss figuring out what you would want to link it to in one direction only however... Outhaul? Traveller? Jib traveller?
This system is to let the rotation off as for sailing down wind. It also allows it put back on again.
When the rotation goes back on, it will be in exactly the same place as it was on the last upwind leg.
- 295 Online
