F16 wings
13 Users
60.2 K Views
pgp
 pgp
(@pgp48)
Men at work.
http://www.youtube.com/watch?v=yO2aRBFwCHA&feature=related
Posted : September 14, 2010 10:10 am
macca
(@macca)
stay tuned.... new professional video of the F20 is on the way <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Posted : September 14, 2010 12:17 pm
scooby_simon
(@simonJlongstaff)
And responses to all the questions above?
Posted : September 14, 2010 1:57 pm
(@Anonymous 37845)
Is it a lot faster than the old 20? The old one can't keep up with the moth once we get on the foils, upwind and downwind.
Posted : September 14, 2010 9:21 pm
(@Anonymous 6548)
Moth can not keep up with the Tornado. Don't think the new 20 will have much trouble 😛
Posted : September 14, 2010 11:42 pm
(@Anonymous 37845)
Haha, for the price and size it should! 54sq m of downwind sail v 8sq m is a big difference!
But have to say I am amazed how quick the moth is compared to the cats in singapore in the 8-15knot wind range.
Posted : September 15, 2010 12:51 am
(@Anonymous 40253)
How about pre 8 knots wind, last time I sailed with a foiling moth is was below 8 knots and he couldnt get it out of the water, a lot of hard work trying though, but when he did manage it really took off and left me for dead, pity he was 2 laps behind, sadly though the hard nosedives took their toll and split his deck, the boat = writeoff!!
Posted : September 15, 2010 4:35 am
(@Anonymous 37845)
Pre-foiling, cats leave us for dead.
But if you are nose-diving that often, then your foils aren't set up right. Can't prevent nosedives, but can certainly minimise their occurance.
Posted : September 15, 2010 4:44 am
(@Anonymous 37882)
And this has what exactly to do with wings on an F16 ?
Went out yesterday in 12-15knots, did 26,5knots..on a board. Since it wasn`t done on a winged F16, it doesn`t belong here.. just like F20, Tornados and foiling moths..
Back to topic, my understanding of the rule is that the boat is measured as platform including ONE wing, so if wings are not folding it doesn`t affect the application of the rule ? So a 2,2m platform with 2x 300mm fixed racks, would measure.. Or am I wrong in my interpretation of the rule ?
Some have said the racks can extend aft of the transom, do they not have to fit into the overall platform length ? This could be an interesting way of keeping the nose up downwind.
Posted : September 15, 2010 8:12 am
(@stewart)
One can add aft racks As I read the rules the length is basically waterline length... But I have a feeling hidden somewhere in the ISAF rules there may well be a requirement to have at least one foot on the boat.. This is due to a crew in a 470 or 505 brother combo the crewing brother
hiked
out from his brothers shoulders. Now my memory could be faulty but someone with a younger brain may have the info at hand... This requirement would limit the
usable
aft extension and may not do more than a winger rudder setup.
Steve mozzies do belong here.. Still grandfathered..
Posted : September 16, 2010 2:40 am
(@Anonymous 37882)
Thanks Stewart, I meant that discussion around whether a moth is faster than a F20/Tornado/my mother-in-law on a skateboard does not belong in this thread, since it`s about F16 & wings/racks.
Now I have another question - if this is an ISAF rule (one foot on the boat) then does this not outlaw racks on all classes, how do the I14s, 18fters etc manage this ? What I understand is that F16 is not an ISAF registered class, does this mean they can ignore ISAF rules? This seems contetious as we all sail under the RRS which is administered by ISAF. And I`m still no wiser regarding how racks are measured in the F16 class, is it platform width plus ONE extended rack, even if the racks are fixed, not folding ? That`s how I understand it.
Not that I`m going to put 30cm racks on the Mozzie, just interested in the rule interpretation. I don`t think that it would change much and would add a whole lot of extra hassle, as most have said, wider beams would be the better option. (And higher-volume hulls.. and a taller mast.. might as well buy/build a proper F16 then.)
Posted : September 17, 2010 2:59 am
(@Anonymous 37845)
Threads evolve and move by questions and responses. As long as it doesn't fall into a dustfight of name-calling, then we don't need thread police. You never know where the exchange of knowledge may go.
To help equalise the narrower platforms, Taipans/Mozzies can put racks on the sides. These are measured from the leeward hull to the wing extension.
Personally I think these give more righting movement for those with wings. Mainly as i look at the rear view of the boat and the hull/platform/rig is acting as a level 3 lever. Scooby_Simon has a different view, and i am fine with that. Down to how you race 'em on the water.
Posted : September 17, 2010 3:11 am
(@Anonymous 37845)
14 Foot skiff rules -
Both members of the crew shall be in contact with the hull, fittings or gunwale assembly. Either, or both, may use a trapeze, individually or simultaneously. Trapezing is not allowed from any point outside the 4267mm length of the hull as defined in Rule 1.
Full rules here --> http://www.international14.org/images/pdfs/march%202010%20class%20rules.pdf
So do the F16 rules have anything in regards to aft wing extensions? And also describe what level of contact one must have with the boat?
Posted : September 17, 2010 3:22 am
(@waynemarlow)
I am not sure why we are asking this question re being further back from the transom, the boat would be so unbalanced and ponderous ( butt sitting in the water ) that you would be nothing but slow.
If you are having to go back behind the beam then your boat has to little foward bouyancy and the easiest way out would be to buy a couple of T foils. Also by going to the max spinny pole length and raising it slightly also seems to help lift the bow at speed.
The skiffs step off the back more to raise the bow because of the hull design, on the cats we should never really need to.
Posted : September 17, 2010 3:37 am
(@Anonymous 37882)
Wayne, my question relates to having a boat without the forward bouyancy of the modern F16 hull shapes. If you wanted to take a Mosquito or Cobra platform and put a full-size F16 rig on it you would want to be 2 feet behind the transom going downwind in most of the conditions we sail in. With the current 7,3m mast (1,2 shorter than F16) we already have too much sail up downwind, even 2-up, and get a few bus-stops on each downwind leg. Of course I would not want an 8,5m mast and sail areas that the F16 class allows if I can`t have banana boards, it makes no sense when you sail in the conditions we get more often than not. I would even prefer a smaller main and spinnaker for the Mosquito for those 28-35knot days.. ie every summer afternoon in Cape Town.
Posted : September 17, 2010 4:55 am
(@dantnz)
Hi All, I'm not sure what is meant by class 2 and 3 levers (and I have a masters degree in engineering!), but this looked like an interesting problem and I have been helping out a student doing these types of problems, so I thought I'd have a go.
So, I drew a couple of very simplified free body diagrams of a 2.2m beam cat with wing and a 2.5m beam without.
The diagram is drawn at the point that the windward hull just leaves the water and the crew(s) is not trapezing. It is simplified by assuming the heel angle will still be zero and it ignores the difference between the side and centreline of the hull. None of this should matter for comparison purposes. It also assumes that the force generated by the sail, height to centre of effort and crew weight remain constant.
So on the diagram F(crew) is the downward force of the weight of the crew, F(sail) is the sideways force generated by the sail, centred at a height of D(sail) from the waterline.
OK, so taking moments around point (0,0), we see that in both configurations a clockwise torque of F(sail)xD(sail) is generated. i.e. it doesn't matter to the mast what the beam is, the capsize force is the same.
Still taking moments about (0,0) in case 1, the righting moment produced by crew weight is 2.5xF(crew) and in case 2, it is also 2.5xF(crew).
So in other words, a 2.5m platform produces the same righting moment as a 2.2m platform with 0.3m wings.
There will however, be an advantage to the 2.5m platform in that is also gains more righting lever from the windward hull itself, since its self-weight will act further from the pivot.
Presumably the 2.5m platform will have less windage as well, and no wing dragging in the water to leeward. The 2.2m hull will probably lift a hull earlier, so maybe a lightwind advantage if the extra weight and air drag doesn't cancel it out.
So, conclusions? Designing a new F16 - 2.5m beam everytime.
Got a narrow grandfathered design, add wings to get the leverage but check this is actually faster once you've done it!
Posted : September 17, 2010 5:02 am
(@waynemarlow)
Its not so much the hull design as simply toooooo much sail area for the conditions, by stepping off the back all you are doing is depressing the leeward hull further which simply is going to make you slower which is simply going to make you more prone to digging the bows in. Bit of a vicous circle I'm afraid.
Posted : September 17, 2010 5:03 am
(@stewart)
Steve,
The I14s have done many things in pushing their envelope.. Including flying I14s. I know of one skipper who build a rack behind the hull to trial.. Ended up the rudder foils were quicker..
I would thus suggest using rudder foils rather than an aft rack on a mozzie or cobra..
Posted : September 17, 2010 7:33 am
pgp
 pgp
(@pgp48)
How many of you guys have sailed a F16 as is? I'm not busitng your chops, it's just that it is a hell of a platform as is.
Talk all you like. It's good that there is interest in the class and traffic on this forum is, overall, good. But for my 2 cents, it (F16) ain't broke and doesn't need fixing.
Cheers! <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Posted : September 17, 2010 7:49 am
(@stewart)
Im not suggesting modifying the rules.. T-foils are part of our rules..
Posted : September 17, 2010 8:17 am
(@jalani)
Pete, the point is that the rules permit a certain amount of tinkering. T foils already exist within the class, AFAIK no one has yet added wings to an existing (underwidth) design but the rules do allow for it. It would be interesting to see whether this
self-cancelling advantage
purported under the rules actually works?
I'd love to see a T4.9 (or Mozzie) sporting wings which extend aft of the transom and whether the boat is then faster as a result?
Of course, learning to steer the thing downwind, in a blow, with a kite up, while trapezing from aft of the transoms will be interesting to say the least!! <img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
Posted : September 17, 2010 9:55 am
(@45degApparent)
This is the thread police. Nice excuse for littering, punk.
Posted : September 17, 2010 10:15 am
Page 3 / 3
