One person enough to right the F16 in all conditions?
Pete,
I get back on the boat by grabbing the dolphin striker as it comes over. Then with an arm on the main beam, one on the hull, facing sort of aft and outward, and I can swing a leg up on the hull forward, and scramble onto the hull, and then the tramp.
I've also experienced getting the bows into the wind, but having it reorient by the time I get to the righting line/pole. Not sure what the solution is to that.
If it is windy enough, the boat will lift back up with less effort and making it possible to slip around the front beam and onto the tramp while she rights. Cool when you can pull it off.
Did it twice on a Blade. Have not had many opportunities on the Falcon (so much harder to capsize and more experienced) and the higher beam with prominent chine may make it harder to achieve.
Hmm. I have a lot of strings up front that get in the way.
My knee jerk reaction is to go to a large heavy duty bag kept under the tramp. It would require some rigging, but if you substitute the bag for your body weight, you could then sit on the
down
hull and haul the boat over, remounting without the need for gymnastic ability. Maybe not the best solution for racing but more certain when sailing alone.
http:/
This may be the problem; you need to let the sterns drift down wind; not swim/kick the bows to the wind.
If you are forward you are sinking the bows; trying to swim them round is going to be difficult/impossible; let the wind blow the higher-flowting sterns to drift away.
Problem is if there is a strong current from the same direction. The bows being pushed down dig into the current. Usually, it results in a 45% angle to the wind.
I agree, the problem can be the issue of getting the bows in the right direction and then getting on the hull in time to right it. In 15kn of wind, should be no problem getting it back up even if you weigh 70lbs. I haven't had an issue recently... but I don't sail the boat very frequently.
- 790 Online
