Another "re-learning" expereince
17 Users
11.1 K Views
(@scubasail)
[#15717]
This last Saturday...we went sailing...for just a quick spin. Then without warning, all of the sudden, out of nowhere, from over the mountain, came a number of thunder heads, lightning and very heavy wind, that changed directions abruptly, often and dramatically.
We couldn't get back to shore before we were into this storm.
We didn't want to shred the sails or beat up the boat or get struck by lightning.... so we uncleated all the sheets and pulled the boat over onto its side and then placed our weight so the boat turned turtle (completely upside down.). That put the sails under water, protected them from the wind..and it put the mast so it wouldn't attract lightning, as readily.
When the boat is turtled, it is a very stable life raft, and the sails are a dandy sea anchor... Everything on the tramp was properly secured and had lanyards so we didn't have to ready anything or worry about losing it.
After about 20 minutes, of sitting on the trampoline of the turtled boat, the storm passed.
To un-turtle the boat, we should have been able to simply sit on one hull's keel and the boat should have slowly return to its side, with the sail parallel to the water's surface. From there the boat is usually simply righted with a righting line.
Well, he didn't properly seal his mast so it had lots of water in it. That meant we couldn't get the thing righted and on it's feet.
After a couple of hours...it really looked like we'd spent the night on the water, floating on the capsized boat.
We both had exposer suits so, though not great, we could have been somewhat OK for the night, on a lake in the mountains of Utah.
As it turned out, just before night fall, a person on shore happened to spot us through a telescope. They called a friend with a boat on the far side of the lake and talked them into going out to look for us.
They finally found us helped get the boat back on its feet and towed us back to our beach.
While you're doing your own penance, I have vowed not to ever again put the bad mouth on Wakeboarders or power boats....
You know, I usually sail with my own PFD and My sailing PFD is home to a small plastic sheath and scuba diver's knife...for cutting away sheets or whatever I may become entangled in during rough weather or a rough capsize. (The knife is equipped with a wrist strap, so I don't accidentally lose it when in the water). The PFD also has a couple of chem lights, a small flashlight, whistle, marine band waterproof hand-held marine radio, and a waterproof handheld G.P.S. I also have a small inflatable orange water weeny. I started carrying that when scuba diving...when I saw how hard it is for people on a boat to spot a bobbing head in the water. I also often carry my cell phone in a waterproof case, also attached to my PFD.
With a bit of sewing and ingenuity, this equipment is attached so it is very secure and doesn't flop around... and out of my way....yet very easy to get to.
Besides looking cool.... I have found through...well...past learning experiences... important things need to be readily available and with you, at hand.... especially when night sailing.... and I find it is easier to have it, than wish I did... and it helps keep simply problems from getting more complicated....
There have been a few times when I thought my day on the water would turn out one way....and it turned out different.
This was one of those times and that stuff would have been swell.... but I didn't have it with me this time...
Bummer to have to re-learn something, again and again...
There's no such thing as a quick spin and equipment doesn't do much good in the car's trunk....
Posted : June 27, 2005 6:18 pm
(@ejpoulsen)
Hey Tom,
Was that at Bear Lake? Sounds like the type of storm that broke my diamond wire/spreader last year.
I'll be up in a few weeks.
Posted : June 27, 2005 6:45 pm
Gary
 Gary
(@hobiegary)
Glad to hear you did not have to spend the night on the lake Tom; glad the both of you are unharmed!
GARY
Posted : June 27, 2005 7:22 pm
(@_removed-account)
Four Star Admiral Registered
I got caught out in a little summer t-storm last week myself, but fortunately we were able to make it to shore before it really hit. I realized that I really don't know what one is 'supposed' to do in the case of lightning. Turtling the boat sounds like a good idea. Does anyone else have experience or thoughts about this?
Posted : June 27, 2005 7:53 pm
MaryAWells
(@maryawells)
Yeah, I have thoughts. I think it is safer to keep the boat upright. I have yet to hear of any instance of a beach cat being directly struck by lightning on the water. All the reported hits that cause damage have been on land.
Occasionally, people get zapped on the water if they are touching stays or other metal or are out on the trapeze. Some of these "zaps" are temporarily debilitating.
A very experienced friend of ours said if he is working race committee on a powerboat, when lightning is in the area, he rafts up with one of the catamarans, because that is the safest place to be.
If you turtle the boat and sit on the bottom of the turtled boat, the highest point is now your head, plus you are sitting in water. Neither is good.
Just my personal opinions.
Posted : June 27, 2005 8:30 pm
Jake Kohl
(@jake)
Tom,
Did you look to maybe 'hoist' a floatable object (lifejacket, throwable, etc.) up one of the halyards to give some floatation to the mast? If the boat were spinnaker equiped, getting to the spinnaker halyard would be pretty easy. Otherwise, but not quite as effective, the jib halyard might sufice. 'lower' (raise underwater) the sail and attach the floaty item to the halyard. Then hoist the halyard to bring the item down the mast. Try to right the boat again. Hopefully, if you find yourself in this scenario again, that might help get the boat on it's side so you can start problem solving with regard to draining the mast.
Posted : June 27, 2005 10:50 pm
Eddie Aten
(@oo7jeep)
Wow.
This is a really interesting thread.
As I very often feel in this forum though, I dont really have anything to contribute in addition, other than to say that again I have learned from you guys.
I would though, like some kind of scientific explanation for why a cat would be less likely to be struck by lighting than a regular boat. Mary, to be sure, has a billion times more experience than I, but it seems counter intuitive. Especially in light of the comment of the other boat rafting up with a cat. AND, if that was true, Id keep my cat away from the lightning rod comittee boat.
Just my .02
E
Posted : June 28, 2005 9:34 am
(@Anonymous 38734)
I was doing some research on the web about lightning protection in a sailboat and found one sentence that surprised me. The author said the only way worse than being in a lightning storm than on a boat with a mast is to be on a boat without a mast. Apparently people are hit more on power boats than sail boats. I also remember when Hobie offered to retrofit my mast to the comptip mast, the pros and cons given said, as a con, the comptip mast reduced the cone of protection from lightning. From this I think that turning the boat over was not the best thing to do.
There is a lot of information on lightning protection on the internet. I have been trying to decide whether or not to ground the mast on my catboat(monohull). Grounding increases the chance of being struck but protects you and the boat. Not grounding the mast decreases the chance of being struck but increases the damage if it is. That may be why the catamaran doesn't get hit as much (no grounding).
The PFD with the accessories sounds like a great idea. I am going to re-evaluate my "preparations for sailing". Carrying a multi purpose tool with knife, pliers, etc. would be good if they are available in stainless.
Howard
Posted : June 28, 2005 10:10 am
claus
(@claus)
I think there is another important security rule that you did not obey: if you go out alone, always let someone know that you are going out and when you are planning to come back. This would have definitively helped you, in our club it is obligatory.
Posted : June 28, 2005 10:17 am
(@Anonymous 38836)
How far were you out? Could you have released your forestay and then righted your boat and paddled in with the mast lying on the boat? I think you could get the boat righted with no mast, but not sure. It might be better than spending the night on the water.
I hate to even think of the lightning thing. That stuff is so unpredictable and no one has survived a direct hit. Even indirect hits on land have killed people. I just hope no one ever finds out what will happen.
Matt
Posted : June 28, 2005 10:19 am
(@dacarlso)
It's nearly impossible to right an inverted cat with its mast off- by 2 people. This is knowledge from my very first experence with a Hobie 16 in salt water. 2 large local fishermen from Cedar Key with a flats boat got us right side up. No way for 2 people to do it, as there is no leverage.
Posted : June 28, 2005 11:25 am
MaryAWells
(@maryawells)
Quote
I didn't say a cat is less likely to be struck than a regular boat. It's just that I have been involved with beach-cat sailing for over 40 years, so I would have been more likely to hear about lightning hitting a beach cat than, for instance, a Thistle. But, actually, I have never heard of it directly hitting any type of small sailboat on the water. Just on land, as I said.
As far as big sailboats, we have personally heard of several reports of them being hit by lightning, but I think in virtually every case the boats were grounded. Even with the grounding, some of those suffered significant damage. If the grounding is not done properly, the lightning can go shooting all around through the interior of the boat. In one case, it traveled right under somebody's pillow in their bunk.
I think the theory about the "cone of protection" (which I believe in) might not apply, however, to unstayed masts. I think the metal stays play an important part in providing the protection. So would you be less protected if you use line instead of cable for stays? I don't know.
I think it is true about powerboats being more likely to be hit by lightning than sailboats. A guy was crossing Biscayne Bay in a Boston Whaler and was hit in the head by lightning (obviously, fatal).
The biggest lightning attracter on powerboats, though, is an antenna.
There is a long, very interesting thread somewhere on this forum about lightning.
But it is all just theories and opinions, and nobody seems to know for sure how to best protect against lightning -- just like nobody knows for sure how to protect against shark attacks.
Funny thing. When I used to work for the Sizzler company, one of the minor selling points was that the boat was safer in lightning because it was automatically grounded, since the hulls were made of aluminum. But now I'm not so sure that is a good thing.
Posted : June 28, 2005 11:30 am
(@jalani)
Having read through what has been said, and adding my own personal and third party experiences, I have to say that in the given scenario I would NOT turtle the boat. My preference would be to drop the main, roll it up nice and tight and lash it to the boat with the mainsheet. Then I'd see about getting back to shore under jib only.
If I didn't have a jib? I guess I'd weigh up my location and either run under bare mast or drift until I was able to find bottom and anchor. You do all carry anchors don't you?
The 'fully loaded' PFD sounds like a great idea although you would risk being given a 'Rambo' label.....
Posted : June 28, 2005 11:40 am
MaryAWells
(@maryawells)
Whoops, I did find one incident in one of the other lightning threads. A Hobie 14 was hit on the water. Nobody injured, but it melted a bow fitting.
Posted : June 28, 2005 11:47 am
(@tcatman)
Anchors???
From a long ago thread on anchors, i remember Rick Bliss talking about a flipped boat being diven onto a lee shore and he commented saying that an anchor large enough to work could not be carried on the cat.
if you are serious about an anchor, what size do you use and what conditions.
My impression is that they are pretty useless on a cat.
Posted : June 28, 2005 1:32 pm
(@jalani)
The anchor comment was sort of tongue-in-cheek. However, having said that, if I'm not racing I have been known to carry an anchor - a 3.2Kg folding grapnel type. When I have used it, I've had no problems with it holding in up to about force 5 or so.
In the situation we're talking about, even if it didn't hold at least it would slow the boat and hold it head to wind.....
Actually, come to think of it I once won a race at the Condor Nationals BECAUSE I was carrying an anchor! - there was no wind at one point and a strong tide so I anchored. By the time the wind filled in with a seabreeze, the rest of the 30 or so boats were a mile or more downtide and downwind! I think I won that one by about half an hour from the second boat
Posted : June 28, 2005 1:56 pm
 JBR
(@jbr)
A big enough anchor to work effectivly in a real squall would be pretty heavy , bulky, and difficult to store on a small cat; these problems would be compounded by the need to keep on board enough rhode and maybe chain to allow an anchor to be effective and not just drag. However, a sea anchor might work quite well. The advantages of the sea anchor is it's very light, folds fairly small and can be lashed to a trap. I could be used out in the middle of the lake and doesn't require a long rhode or chain. You would drift some but in your typical 10-20 min squall that may not be far enough to worry about (if you were that close to shore you'd just head in instead). In the scenario above, you might just drop all sails, lash them to the tramp, and deploy a sea anchor from a bow bridle.
A sea anchor would also be a useful thing to have on board for regular capsizes in higher winds when you're having trouble keeping the bows into the wind to right the boat (could come in real handy if you capsize on the coast and want some time before being blown onto a rocky shore or in the even you capsize in offshore winds and are having trouble righting the boat). To work properly you'd need to run it off a bridle between the bows. I don't know if you could run it off a spi pole - anyone ever try that? They come in a wide range of sizes and you need to size it for the size of the craft and the amount of drift you're willing to tolerate. The only downside I know of is that they're actually fairly expensive. The inexpensive drogues used by fishermen to drift fish are NOT suitable.
How many people out there have a sea anchor on board and have any experience using it on small cats?
Jerry
Posted : June 28, 2005 2:00 pm
Jake Kohl
(@jake)
Quote
Why is this?
Posted : June 28, 2005 2:16 pm
 grob
(@grob)
Quote
Why not just drop the whole rig, mast, sails etc, wait for the storm to pass, then rerig the boat and sail home.
Posted : June 28, 2005 5:17 pm
 grob
(@grob)
Quote
Quote
You guys are no fun, someone was supposed to say "how do you put the mast up while out at sea" then I get say "its easy with a rig like this" and post this...
[Linked Image]
Our rig actually came down last weekend due to operator incompetence on my part, we were about a mile out and did indeed manage to put it all back up and sail home.
Gareth
www.fourhulls.com
Posted : June 29, 2005 12:23 pm
 JBR
(@jbr)
They're designed to let you drift, just a little slower than you would otherwise, so you can go trolling for fish. They're almost like a rudder in that if you're not moving fast enough they do almost nothing. If you were on the coast and drifing into rocks good luck. I actually tried one. I used a medium sized on and maybe a really big one might have worked better but I doubt it. These are big PVC cones with a large hole at the end so they work kinda like a windsock in the water. The real sea anchors look like a full parachute (no hole, flatter like a disc rather than a cone, and a bunch of small lines at the perimeter, lighter material). A real sea anchor has MUCH more holding power than a fisherman's drogue and if you size it right your're close to dead in the water (with a very slow drift compared to a drift anchor). You feel like you're moored on a bouy (but you are drifting very slowly). It's too bad since the cone drogues are generally not only cheaper but also less tangle prone since it's easir to tangle a parachute rigged setup than the cone setup which typically only has 3 to 5 web straps from the cone to the anchor line. That said, tangling of the lines doesn't seem to be a problem with a real sea anchor unless you were really sloppy when stowing it.
If anyone else has any experience with these various options please share it.
Jerry
Posted : June 29, 2005 12:47 pm
(@dermot)
[quote
[Linked Image]
Gareth
www.fourhulls.com
Gareth,
Is this you project finally complete ? I cannot see the hulls - the photo is too dark ? And your site has not been updated
Dermot.
Posted : June 29, 2005 7:46 pm
 grob
(@grob)
Hi Dermot,
It is certainly getting closer to completion, I think there is still alot of work to do though, we are pleased with the way it sails, it could do with being a bit faster, we have quite small sails at present 2x 7m, we are going to upgrade to 2x 10.3m thats 220 sqft.
I don't have any really good pics of the hulls, but attached are a couple more, I can't seem to get the black hulls to photograph very well!
I will endevour to update the website this weekend.
All the best
Gareth
[Linked Image]
[Linked Image]
Posted : June 30, 2005 9:02 am
(@stilettodude)
That is one nice looking boat! When sailing off the wind, do you put the sails to the outside like a wing and wing fashion? I know that would be slow. How does the sails affect the tramp area? It almost looks like on either tack the sails would be in your way.
Clayton
Posted : June 30, 2005 9:47 am
MaryAWells
(@maryawells)
I got one of your pictures lightened up in Photoshop and have attached it (I hope), so you can see the four hulls.
Posted : June 30, 2005 10:04 am
(@jalani)
OK Gareth, I give up... Where do you sit? How do you hike out/trapeze?
Oh, I get it - it's for pygmies!!!
Posted : June 30, 2005 10:08 am
(@dermot)
Hi Gareth,
That's great. That rig looks really classy. I look forward to seeing the sailing shots.
Seeing that rig reminds me of the question that people with windsurfing background always ask me: With all the new technology around, why do catsailors still fasten their battens with bits of string Do windsurfing type adjusters really add that much more weight ? The ones in the photos look very streamlined. Having asked this question, I have to say that I know nothing about the technicality of windsurfer rigs.
Wouter - Only one paragraph
See ya,
Dermot.
Posted : June 30, 2005 10:20 am
(@jalani)
How much does the whole piece of kit weigh, Gareth? How have your trials gone?
As you've apparently done such a great job of making a radical piece of thinking into a reality, how about a thread dedicated to discussing your progress - I for one would be really interested and I'm sure others on here would be keen to know more too!
Posted : June 30, 2005 10:43 am
(@dermot)
Quote
Quote
No, and the windsurfing rigs are really nice, high tech and cheap, Our rig has camber inducers and an allan key to adjust the batten tension.
So, why are we not using camber inducers on cats
Dermot.
Posted : June 30, 2005 2:09 pm
 grob
(@grob)
I have tried to answer this on a new thead so as not to hog this one
http://www.catsailor.com/forums/sho... sed&sb=5&o=&fpart=1&vc=1
Posted : June 30, 2005 2:28 pm
Page 1 / 2
