Aspect ratio questions
High aspect ratio = Long and skinny
Low aspect ratio = short and fat
High aspect has lower drag and vs lift generated, ie: higher potential speed in our application. The lift created by sails is generated in the first 30% (from the luff). In a lightweight platform like a cat, that does not need a lot of force to overcome it's inertia and drag thru the water, high aspect allows for higher speeds for a given wind.
OK, to answer your question relative to two sails with the same total sail area, the one with the longer luff (and thereby a shorter foot) will be the one with a higher aspect ratio.
The new (to some) Square Top type mainsails you see on most newer designs (F-16, F18, A cats, etc.) were developed because with a fixed rule to total sail area, the sail makers figured out that they can generate the most lift by having a shorter foot and longer luff. In effect they were moving the sail area from the foot up to the top, in the square head, vs. the older triangle sail designs like you would see on most boats prior to the advent of the Square Tops.
So, if you have a choice but are limited to a rule for
Total Sail Area
you would be wise to have a
high aspect ratio
type sail made. It will have a square top and look much more like a rectangle than the older triangle type sails. It will also generate more lift and less drag.
You can also keep the same luff length, same mast, and just add the square top, shorten the foot to keep the same sail area.
Then rake the mast back a little to compensate for having moved the Center of Effort (CE) forward (by reducing the sail area in the aft part of the sail, increasing the sail area in the forward part of the sail).
Gary
Ryan,
The class rules allow a maximum of 185 sq.ft. of soft sail main and jib combined. We have formulas for measuring square-top and pin-top mainsails, and jibs. However you elect to divide up the area between the sails is fine. Most of the jibs measure out at 44 sq.ft., so we typically cut the mains to 140+. There is also a maximum mast height, and the mainsail may not extend above the top of the mast.
Several members of the fleet are sewing their own sails from pre-cut pentex panels. Howard Alexander also sews them for sale through CFI (formerly IFG). Most of us are opting for a medium-aspect square-top and it seems to do fairly well. The kits come oversize so there is some leeway in how you cut the leech.
I'm the class measurer, so should you choose the do-it-yourself route, we can lay out and measure the sail before you cut it.
Eric
BTW, there was a sail number 1100 on the banner at Carolina Sailing club - is that your boat?
There is no restriction on sailmaker or shape - just total area. If you take a look at http:/
- 967 Online
