Can any of these haul a boat /trailer?
Checking to see if any of these cars could effectively haul a cat/trailer. This will be a disassembled cat, so the width of the trailer will be around 7 feet, not the 8'6
like the
normal
cat trailers.
I guestimate the trailer, cat, and equipment will be around 900-1000 lbs. max.
Here's the choices:
Chevy Aveo - 103hp - 107 ft. lbs. torque
Kia Rio - 110hp - 107 ft. lbs. torque
Toyota Yaris - 106hp - 103 ft. lbs. torque
Honda Fit - 109hp - 105 ft. lbs. torqueI don't expect to have any great acceleration or fuel economy, but it would appear there is enough horsepower to haul something like this..
Are there any other considerations for these vehicles? Enhanced engine/transmission cooling? Bigger brakes? Nitrous? <img src=
N20 with a galvanzied trailer... hmmmm...
Centerfold boy,
By
trailex
trailer, are you referring to an aluminum type trailer?
It's for a T boat. WOrking on building something, so I guess I have flexibility in materials and design.
From Wikipedia... I learn something every day..
[color:
blue
]The term
horsepower
was coined by the engineer James Watt (1736 to 1819) in 1782 while working in the performance of steam engines. This occurred while using a mine pony to lift coal out of a coal mine. He conceived the idea of defining the power exerted by these animals to accomplish this work. He found that, on the average, a mine pony could pull (lift by means of a pulley) 22,000 foot-pounds per minute. Rather than call this
pony
power, he increased these test results by 50 percent, and called it horsepower i.e. 33,000 foot-pounds of work per minute
Horsepower is only one factor to consider when selecting a vehicle for towing. I think a vehicles weight, breaks, transmission, etc. also needs to be considered. If I were to try to tow my N20 and galvanized trailer behind a small car with sufficient horsepower, I may end up with the
tail wagging the dog
the first time I tried to stop of go around a corner.
That's kind of what I was thinking, although I doubt seriously that four 250lb dudes could fit in these little shoeboxes.
Most people call these cars
speedbumps
around here. $4.00 gas? nobody cares around here. Ferraris only get 9 mpg anyway. Bentlys get about 12. What do Escalades get?
Mike Dobbs have hauled his Tornado on an alu tilt trailer behind a Morris Mini. He did not mention any trouble.
We trailed our Tornado extensively with lots of gear behind a Ford Focus station wagon with a 1.6litre engine. No worries, just a bit slow going uphill.
Just watch out for local regulations on how much you can tow with a small car. There might be some legalese there.
I tow a H16 on an oversized galvanized trailer (combined weight about 720 lbs without gear) with my Maza Protege without any problems. The cars you listed here are a bit smaller, but if you check the European specifications for these cars you can get a better idea for the true towing capacity (the US specs will tell you not to tow anything, even for my 2.0 liter Protege5). I looked up the Yaris, and the listed towing capacity for the 87hp model is 550 kg without trailer brakes, so about 1200 lbs.....so you should be fine.
I don't think there would be many hills where I intend to travel. Good to know the Ford Focus could do it.
Don't intend to have a tilt trailer, either. Too much windage.
I think the Mini Cooper might have more horsepower than the
compacts
I list, but at least there are those out there who have experience with this, so I know it's possible.
As for regulations, I am only aware of FL DOT rule that requires any trailer with more than one axle (or over a certain weight) has to have trailer brakes on EACH WHEEL.
Not many trailer mfg. companies do this, which leaves the buyer in violation of DOT.
Yes, I've received a
reminder
of this little detail from a
friendly public servant
a while back.
Thanks Arie. I see you're just up the road from me in Ft. Myers. Any chance you'd be free to sail once in a while?
Where do you usually float that H16?
Just checked and the steepest trailering we did with the Tornado behind Focus was 10% climbs. Speed limit was 80km/h and we could follow the traffic by gearing down.
Towing a tilt trailer is usually murder for the mpg if you go long/fast <img src=
/> By breaking the Tornado down we could tow the hulls in the wake behind the car, but the mast poking up and forward over the car still made for some drag.
I find driving a largish car is much more comfortable when driving on highways for 6-xx hours. But money is what decides in the end.
Mike trailered his T from Calif to FL, but not behind the Mini and not in tilt mode (I think). He should be able to share some good information next time he checks in here.
Pretty much ANY car can tow 1,000 pounds. I've towed a Hobie 16 and 18 with a Ford Escort, Toyota Corolla hatchback and VW Rabbit diesel. I've towed the Prindle 18.2 with a Nissan Sentra. All of these cars had 4cyl 1.6ltr or smaller engines with around 100hp (actually torque is a better indicator for towing ability). They all did the job just fine.
I WOULD HIGHLY RECOMMEND that you install an after-market transmission fluid cooler on the vehicle though! You can buy them online and they're easy to install. Just mount it in front of the radiator, connect the intake and output tranny fluid lines and add more tranny fluid to make up for the increased hose and radiator length. It's the transmissions on these smaller vehicles that suffer when towing and keeping the fluid cool goes a long way into making the tranny last.
We've found it easier to cut in half the recommended service intreval on transmission fluid is easier than installing aftermarket coolers and can give you an earlier indication of problems, or one forming.
Research and find out what gears are actually overdrive (in some newer manuals, 4th as well as 5th gear), less than 1:1, and avoid using them under load (up any grade). Same is true for automatics, be careful of the lockup to overdrive, if you notice the transmission shifting in and out of overdrive excessively, turn off the
O/D
or shift in to 3rd or Drive.
One boat, two trailers, two boxes, and I think there's a coupla kayak stuck in there.
This guy does 1000 mile round trip deliveries for me once to twice a month. Two boats and 5 kayaks is the max so far. 32 MPG +or- he says.
We use to double stack ALL the time WHEN 200 boat regattas were common. DUH never see those days again <img src=
/> <img src=
/> <img src=
/> <img src=
I've used a 1989 VW Cabriolet to tow my T on a breakdown trailer repeatedly(500+miles 1 way). Trailering is less a function of H.P. and more closely related to braking the load. You don't want to be pushing through a stoplight if you are unprepared or underbraked( by neglect or design).
- 664 Online
