Cat Trax Leaks
(@Anonymous 32191)
[#23173]
I bought some Hobie cat trax used.Unfortunatly the tires have small holes in the side walls (seller did not mention this).I brought them to a garage and the guy put some plugs in them but was not sure they will hold.Any other suggestions.I was wondering if you can put a tube in the tire?
Posted : July 14, 2008 8:15 pm
(@Anonymous 37989)
Yes on the tubes! There was a recent post about just that. Do a search here to find the links. You can also use the patch in a can, but it will gum up the insides, and may make it harder to remove the tires should you ever decide to get tubes. You also have to spin them for a long long time to spread the goop around inside the tire.
Posted : July 14, 2008 10:39 pm
Jake Kohl
(@jake)
Quote
Rick's got the tubes here in the Catsailor store if I remember correctly - they were tricky to find.
Posted : July 15, 2008 7:30 am
(@edgarapoe)
Here is the link to the tubes
https://store.catsailor.com/pc/viewPrd.asp?idcategory=0&idproduct=20045
Actually, this new store is really pretty easy to find things.
Of course there is shopping by category, but Also by brands or simply key words in the search.
I found the tubes by selecting Browse by Brands, then Cat Trax, and there were the tubes.
Also, I typed tubes in the search box and the Inner Tubes were the first item that came up.
Simple, really. <img src=
And tubes are the only way to go. I was really going nuts with my Cat Trax, Euros, etc. and Then I got the tubes and no more problems.., they are always inflated and ready to go. No more last minute pumping.
Rick
Posted : July 15, 2008 8:58 am
(@genealex)
here's the thread:
cattrax vs eurotrax
Posted : July 15, 2008 3:47 pm
(@Anonymous 32191)
Thanks Guys
Posted : July 15, 2008 3:55 pm
(@edgarapoe)
No need to use
verses
anywhere. There is now only ONE beach wheel manufacturer -- Cat Trax.
Euro stopped marketing in the USA because of the dollar value and Cateez can no longer get wheels -- discontinued until further notice, and it has already been 7 months.
Rick
Posted : July 16, 2008 11:05 am
