Eurotrax vs Cattrax beach wheels
17 Users
35 K Views
(@selfinficted)
[#22646]
Thinking about purchasing some beach wheels.I know that eurotrax has plastic bearings and hubs and seem to be very reliable,What type of bearings do cattrax use??, I know they have an alloy hub,Do they have any corrosion problems within the wheel?? Do they roll the same??
Any input welcome,as if there is no difference i could save my self the $150.00 AUS dollars difference
Posted : May 13, 2008 8:51 am
(@_removed-account)
Four Star Admiral Registered
CatTrax have never failed me in the last 7 years of mostly saltwater sailing. They are TOUGH!!!
Doug
Posted : May 13, 2008 9:22 am
(@Anonymous 38725)
Cat Tracks have plastic or nylon needle type bearings, about 1/4
diameter and about 5
long, I would guess maybe 18 or so per hub, they do not fail as long as you keep the cotter pins that hold the end plates on in good shape. They might get some sand in them when launching in surf, by you can easily wash it out in the water or with a garden hose, just roll them under water and it washes out.
The only problem I've seen is after many years, the big black rubber tires may start to leak (or maybe it's the valve stems) and you will have to use a bike pump or gas station air hose, but be carefull not to overdo it, and pump them up. I have not had to put any air in the ones I bought new a year ago. The last set I had was about 8-10 years old and also held air pretty long (2-3 months) before I had to put any in.
Posted : May 13, 2008 10:02 am
MaryAWells
(@maryawells)
I don't know about Australia, but Eurotrax are not available any more in the United States.
Posted : May 13, 2008 10:46 am
(@selfinficted)
Thanks for the information
Thanks timbo on the bearings,i wondered if they where plastic or not
Hi Mary ,we can still get the eurotrax here but as i said they are about $150.00 more
Posted : May 13, 2008 10:50 am
(@_removed-account)
The eurotrax have adjustable cradles (i believe) that can be easily adjusted for different sized cats where the CatTrax are determined by the length of the axle and the holes for the cotter pins.
Newer ones have holes for 8’ & 8’.5’ cats (i think), but you still need to remove cotter pins and re-pin them to adjust... not hard, but not an on-the-fly adjustment. Pliers are needed and would wear out the cotter pins.
I have CatTrax and ended up latter needing 1. cradles added and 2. an axle extender for my new (8 1/2') cat. In the long run... it cost me more than if i bought eurotrax
Posted : May 13, 2008 11:46 am
(@TurboCat)
The bearings in the eurotrax are black plastic type material. I have eurotrax and enjoy the adjustability. I can use them on my boat or freinds boats when sailing.
Posted : May 13, 2008 11:51 am
(@hullflyer)
The bearings in Florida Sailcraft cattrax are made of delron and there are 20 per hub. I have used cattrax for over 15 years and the only problems have been with the valve stems, either replace them every few years or add inner tubes.
Posted : May 13, 2008 12:32 pm
(@jeremyleonard)
As people have said, the cat trax are bomber. I bought a set of eurotrax for our fleet and they lasted about 1 summer before they needed a rebuild. We have had a set of Cat Trax from the '90's that are still going strong. You may want to get some inner tubes for them as they are known for springing leaks around the bead and valve stem. It's an easy fix.
Posted : May 13, 2008 4:43 pm
hobiesailor
(@hobiesailor)
What inner tubes do you use? I have one wheel that leaks pretty regular. But I agree Cattrax are rock solid. I was lucky, mine had a sleeve with 2 holes and a bolt to expand them when I went from TheMightyHobie18 to F18 width.
Posted : May 14, 2008 11:22 am
(@jeremyleonard)
The tubes I have here are ATV tubes 22X11X8.
Posted : May 14, 2008 3:06 pm
(@Anonymous 12258)
Well thanks for the karma, dude! Just when a thread starts about cat wheels, and I'm thinking about whether my old cattrax may need an inner tube, the damn things blow away in a storm & float across the lake never to be seen again. Guess I do need an inner tube after all.
Posted : May 19, 2008 9:42 pm
(@Anonymous 6548)
Have never seen Cattrax but use Eurotrax and I have not looked back.
Can not believe people still persist with the plastic rollers or thin tyres.
Posted : May 20, 2008 4:15 am
(@edgarapoe)
We sell inner tubes on our site, right here! at https://store.catsailor.com/ProductCart/pc/viewPrd.asp?idcategory=0&idproduct=20045
Also, in the USA the only beach wheel still available are Cat Trax, so not much debate.
Euro stopped marketing here and Cateez cannot get wheels.
Rick
Posted : May 20, 2008 7:01 am
Jake Kohl
(@jake)
Cattrax build a good product - I bought a pair new in 2000 and just sold them with my F18 a month ago. After the initial assembly, I only had to put air in one tire once in eight years.
Posted : May 20, 2008 7:16 am
(@beachwheels)
Newby Registered
Do the Cattrax still use those aluminum hubs? I went to their website and that's what it said there. So I'm thinking all those rusty and corroded car rims you see on the streets in winter, you know they are done after so many years. Eurotrax are using plastic hubs which can never corrode in a thousand years. So the question basically is: Are you willing to pay more for your EuroTrax or do you risk having to buy a cattrax every two or three years. And of course there are always exceptions meaning some cattrax will last a lifetime others a month. All I can say is that you don't see Cattrax in europe anymore as the Eurotrax have proven their worth and durability. And bad hubs are the reason for getting flat tires too. The valves will not give up as fast in saltwater as metall hubs.
Posted : May 20, 2008 8:24 am
Jake Kohl
(@jake)
Quote
You're probably seeing eurotrax in europe because you don't have as high shipping costs to get the cattrax from the states....and aluminum doesn't rust. <img src=
/> Many people have had cattrax in saltwater environments for a long long time.
With the dollar value like it is now, I doubt you can even buy a set of eurotrax for a reasonable figure.
Posted : May 20, 2008 8:37 am
(@dacarlso)
Has anyone fixed
hubs
on their really old Cattrax? My really old set had mild steel tubes with the rubber tires glued to them: the Delrin/Nylon rods rolled against the aluminum axle just fine-- until the steel tubes rusted into a big horrible mess, with leaks. I fiberglssed inside the tube but this was very messy, with leaks.
Posted : May 23, 2008 3:21 pm
(@genealex)
I Just happen to have disassembled one wheel from my cattrack, going to take it to a local tyre centre to see if the can plug a leak foor me. Does anyone know if that is feasible or not? Anyway I have taken some pictures of my trusty old cattrack to illustrate some of the points people have made in this thread. I don't know my cattrax's age, I bought it secondhand together with my boat. It appears to be old, but apart from the leaking tyre it does its job well.
Posted : May 24, 2008 10:57 am
(@genealex)
view of the bearing rollers in place
Posted : May 24, 2008 10:59 am
(@genealex)
Roller diameter after a being used a lot of seasons
Posted : May 24, 2008 11:02 am
(@genealex)
The bearing rollers, all 20 of them
Posted : May 24, 2008 11:03 am
(@genealex)
The wheel with its leaky tyre
Posted : May 24, 2008 11:04 am
(@genealex)
Closeup of the hub
Posted : May 24, 2008 11:05 am
(@genealex)
The Leak is inside the orange triangle. Does anyone have an idea how to fix it?
Posted : May 24, 2008 11:35 am
PTP
 PTP
(@CaptainPP)
you can get those little plugs that work on real tires at walmart. I think you basicly shove a plug in through the hole with a wire type thingie. I wonder whether they would work. I am not sure though, they might rely on higher PSI. Worth a shot though I am sure given the $$ to replace one of those tires.
[Linked Image]
Posted : May 24, 2008 12:36 pm
(@genealex)
Thanks for the suggestion, it could be worth a shot because it wouldn't involve lifting the tyre from the rim. I'll try to locate a kit like that in the good old Netherlands.
Posted : May 24, 2008 1:48 pm
(@flatlander)
Reminds me of the tire repair kit they gave my Granddad when he rode a motor-bicycle for the Post Office, Fresno, CA, 1906...a knitting needle, a package of rubber bands and a foot pump with the instructions to keep stuffing them in 'til it stops leaking.
Posted : May 24, 2008 5:58 pm
(@Anonymous 8992)
Quote
Add some superglue and something to scratch up the area around the leak and thats about all you need to fix a leaky tube or tyre especially one running less then 5psi.
Darryn
Mozzie
1782
Posted : May 24, 2008 6:06 pm
(@Anonymous 335)
Those tire repair kits do not work in side walls and most are for tires with steel belts. Just install a inner tube or patch the leak from the inside at a tire shop.
Posted : May 25, 2008 6:13 am
Page 1 / 2
