eXploder 23, mini-trans tri..
22 Users
64.5 K Views
Jake Kohl
(@jake)
[Linked Image]
Posted : March 12, 2007 3:20 pm
Luiz
 Luiz
(@luiz)
Thanks for the drawing! I guess it is probably feasible in a very light 23 ft folding tri, but not in bigger ones - especially offshore.
Posted : March 18, 2007 8:44 pm
(@Anonymous 13024)
Some new photos have come on-line. Still nothing on practical righting tests, but some of the structure for moving the crossbeams is visible.
http://www.exploder.info/images/stories/yacht/budowa/wyjazd01.jpg
http://www.exploder.info/images/stories/yacht/budowa/wyjazd02.jpg
http://www.exploder.info/images/stories/yacht/budowa/wyjazd03.jpg
Posted : April 11, 2007 5:14 pm
(@mauganh17)
That boat really makes me giddy.
Posted : April 11, 2007 5:46 pm
Jake Kohl
(@jake)
Ooohhh man, that would look good behind my truck. <img src=
[Linked Image]
Posted : April 11, 2007 6:45 pm
(@_removed-account)
Four Star Admiral Registered
So availability? Price? Could it replace F boats as alternative?
Posted : April 11, 2007 7:26 pm
(@basketcase)
so, how do you keep the rig on the boat when righting? look at jake's drawing and tell me where the shrouds are.
Posted : April 11, 2007 8:58 pm
ncik
 ncik
(@nickb)
We don't know yet...still waiting for a photo or video?
Posted : April 11, 2007 10:55 pm
MaryAWells
(@maryawells)
And I thought a Tornado tilt trailer was scary on the highway! <img src=
Posted : April 12, 2007 2:26 am
(@_removed-account)
This boat is far different from the F-Boat design mentality. They are not comparable.
As far as problems:
Will this boat fit under bridges on the trailer? It looks tall.
How will the mast be supported when the boat is being righted?
And how do I launch this thing? It is too wide for a hoist and too wide for a ramp launch.
Every time I look a tris they look cooler and cooler to me.
Posted : April 12, 2007 10:39 am
Chris
(@greencj)
Quote
Perhaps it launches with one amah down, one up, which should fit on a ramp. The second amah would then be lowered on the water. The mast could be supported by sister shrouds from the edge of the center hull deck until both amahs are locked down and the side shrouds tensioned.
Chris.
Posted : April 12, 2007 11:08 am
(@mauganh17)
Quote
Could we maybe see a VWM eXploder 23 in the future?
Posted : April 12, 2007 11:35 am
Chris
(@greencj)
I made a rough estimate of the height on the trailer using a couple of pictures from the exploder website, assuming 23' length on the plan view and get something like 11' high on the trailer.
[Linked Image]
Upsized plan view. Assuming a 23' center hull length gives a length from the pivot point to the edge of the amah of just over 7'
[Linked Image]
Rear 3/4 view. Using the measurement from the first picture and guestimating the bed height of the trailer and the height of the center hull I get to just under 11'. A quick search revealed a clearance standard of 14' on US Interstates in urban areas and 4.5m (14' 9") on German roads. So it should be OK (similar to a F31OD on the trailer?) - just look out for low trees!
Chris.
Posted : April 12, 2007 12:05 pm
Jake Kohl
(@jake)
Mary, you're RV is taller than 11'.
Posted : April 12, 2007 2:02 pm
(@Anonymous 13024)
About launching. I suppose there is a rather large difference between the US and Europe in that we have more mast-up storage and largish ramps or beaches available at our clubs. Many clubs also offer berths, or for boats like this, end berths.
Posted : April 12, 2007 3:12 pm
(@Anonymous 13024)
Here is a message from the builders:
Exploder 23 is experimental water craft. Many unexpected technical problems appeared during execution of the project, which resulted in much longer realization time. Finally the boat will be launched on the Bay of Gda&#324;sk waters on7-8th April and middle April will be dedicated to the test on the water. Provided that the test results are satisfactory, at the end of April we plan departure to Carnac in France, where the boat will be presented on EuroCut regatta, and than further tests on the open ocean. Final target of our preparations is to sail from Cadix to San Salvador and compare our result with the results of the biggest multihulls that will try to beat that record this season. If the boat passes that exam safely we plan to sail from Bermuda Islands to Plymouth in July. Both trials across the Atlantic will be taken in two-man crew – Wojciech Kaliski and Adam Skomski.
There is a full set of moulds for serial production of Exploder 23. In principle we could already offer it for sale, however taking into consideration the experimental character of the construction we have decided to take the test first and confirm that all new concepts and technical solutions are a success. Except of that during the production of a prototype we realized that some elements should be re-designed to lower the costs of the serial production. For instance we will be able to make out rigger hulls and cross beams in the autoclave very soon.
Taking all above into consideration the price of the yacht hasn’t been calculated yet. Before we started the project we estimated the price to be € 70-80 thousand. However it is sure now
that the boat will be more expensive. We expect rather the price of € 90-100 thousand and the final price we will confirm having finished the tests on the water – in May or June. Nevertheless we hope to offer you for this amount the most exciting small racing yacht that enables easy transportation, preparation for sailing and launching. The first photos, film and data regarding the tests will be available on our web page at the end of April.
Best regards
Krzysztof Kozerski
www.exploder.info
Posted : April 13, 2007 2:12 pm
Jake Kohl
(@jake)
[sentence enhancer]!! That's bloody expensive for a 23' boat! $120 to $130k US
Posted : April 13, 2007 2:18 pm
(@Anonymous 16068)
Each 2 feet of that boat is almost the price for a new Hobie Tiger!
Posted : April 13, 2007 4:06 pm
(@Anonymous 13024)
It's a huge amount of money, half a decent home around where I live. Good thing that you can homebuild such a boat if you want to, with a pretty good shot at a decent result (sans the folding/righting system). However, a lot of people buy 30foot monohulls which sails like pigs at the same cost. At least you will have fun, exitement and speed with the
exploder
. But the price is just one side of it. What I find more interesting is the total faith in their righting system, which it dont sound like they have even tested yet. Interesting times coming up I think!
Posted : April 13, 2007 5:24 pm
MaryAWells
(@maryawells)
Quote
Yeah, but it is not attached to a little ball on the back of another vehicle.
Posted : April 13, 2007 5:32 pm
 Karl
(@sogncab)
It'll be going on my
things to buy when I win the lottery
list. One of these days <img src=
Posted : April 13, 2007 6:59 pm
Jake Kohl
(@jake)
Bang for buck, I think I would still look at the Corsair/Farrier line.
Posted : April 15, 2007 7:50 am
Luiz
 Luiz
(@luiz)
Quote
...Many unexpected technical problems appeared during execution of the project, which resulted in much longer realization time...
I've been there, or, better, I AM there.
For that price you can have my boat, that is, IF it is ever finished...
Luiz
Posted : April 16, 2007 5:57 pm
Luiz
 Luiz
(@luiz)
Agreed. Unless they succeed in making a decent self righting system. That would allow pushing it to the limit. Then the
smallest and fastest self righting boat in the world
would be sold at a premium. In France, though...
Posted : April 16, 2007 6:04 pm
(@Anonymous 13024)
Another message from the builders/developers:
Quote
concerning the Exploder we are now making sailing test and will be on
Carnac France beguinning of May ...
Tests sailing are very good , just we have some delay for hydraulic system
beam ...
Price could be arround 85000€ ready to sail ... we are calculate now 😉
Delay with the hydraulic beam system.. Not surprising. This will be an interesting story to follow.
Posted : April 21, 2007 2:19 am
Luiz
 Luiz
(@luiz)
Quote
beam ...
Read:
Sailing tests are ok, but it will take forever to find a hydraulic system that is light enough to keep the boat floating on its lines.
In order to be able to self-right the boat, the whole hydraulic setup, with tubes, pumps and energy sources, can easily result heavier than the rig. Perhaps even heavier than the entire boat.
Luiz
Posted : April 21, 2007 7:10 pm
TEAMVMG
(@TEAMVMG)
I am taking my boys to Eurocat Carnac this weekend so I will be on the lookout for this machine [Hunt it down if necessary] and report back . must charge up my camera.
La Trinite [just along the beach] is one of my favourite spots on the planet. Its a multihull heaven. Not sailing in Eurocat this year so I can compensate with lots of snooping around!
Au Revoir!
Posted : April 23, 2007 2:13 pm
(@tornadokc247)
I would suspect any hydraulics would be run by a hand pump...like a car jack stand. No need for an engine-operated pump & fuel source...plus making sure it can work while inverted <img src=
Quote
Quote
beam ...
Read:
Luiz
Posted : April 23, 2007 3:25 pm
Luiz
 Luiz
(@luiz)
Quote
That's correct if you want to right the boat using the hydraulics. If you want it to SELF right, though, you'll need an automatically activated pump.
Posted : April 24, 2007 9:38 am
(@tornadokc247)
Well, let's agree to disagree on what is meant by
self right
My Tornado w. carbon mast can be
self-righted
with me leaning off the striker... outside assistance not needed.
Quote
Quote
Posted : April 24, 2007 3:57 pm
Page 3 / 4
