Filament winding machines?
You can make a lot more than tiller arms with this. I have seen them used to make composite over wrapped pressure tanks.
I have always ignored these type machines when I see them surplus. I assumed they would be more trouble than than I wanted to deal with. I would like to hear this works for you.
(FYI, I remember reading that one company debugs the winding using nylon)
None as far as I can tell, I have not picked it up yet. I figure I will have to turn something on the lathe to make one.
here is a link to it
http:/
That's good...I was thinking last night that most of those servo and control components in that electrical cabinet are probably single phase and powered through a step-down transformer. A little re-wiring would probably make it work off single phase 110V or 220V. The only thing that might require 480v 3phase would be an induction motor - but I don't see one on there or the need for one in that machine.
Since that has some serious automation/programability, it should be possible to make things like a single piece, programmed, filament wound rudder head and arm in one piece.
The only problem is that I have no idea how to program it. That's fonna require some learning!
- 944 Online
![[Linked Image]](http://i46.photobucket.com/albums/f149/black92se/e41d56ea.jpg)
