Kite retrofit
hi guys
i am putting a kite kit that i got given on a hurricane that i just acquired and am wondering the best way to attach the head block.
i have seen 2 ways:
1. a fixed bracket
2. string allowing the block to turn on the mast
does it matter or is 1 better than the other?
cheers
Ant C
Posted : July 29, 2011 1:13 pm
Also the string method is much easier/cheaper to rig up, just drill a couple small holes in the luff track and tie the string through a turning block, you are good to go, vs. buying and then trying to mount a bracket on the mast. And if you ever want to remove it or move it up or down, that's much easier with the string too.
Posted : July 29, 2011 2:02 pm
Forum Information
- 436 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
