Lewmar VF Racing Blocks?
I was looking at my original 1985 blocks on my H16 the other day thinking they should be updated over the winter... which was reinforced by a friend (thanks Jeff).
I did some searching and found a Lewmar VF Racing 60mm Vf Triple Ratchet Block with becket & cam and matching 60mm VF Racing triple for under $270 for the pair. I'm assuming these blocks are similar to the 57mm Harken Carbo blocks? I like the idea of going with the larger 60mm 6:1 blocks as I'd like to use a 10mm or even 7/16" main sheet.
Does anyone know anything about the Lewmar VF Racing blocks or see any reason why this system wouldn't work well on a H16?
I use lewmar r60's and 90's. they are very nice. for x-tra line dia. you can inter change the side plate's and then use a large size cam cleat. i use 5/8 reggata braid on my main. very easy on the hands. after 3 failures of ronstan blocks i have had no problems with the lewmar. very smooth
I have used Lewmar and the only problem I had was parts. I could get parts but it always took a week or 2
I now use Harken ratchomatic carbo which is by far the best thing I have ever seen. It's almost as big of an improvement over the old harken's as harken's were over Seaway in the 80's.
- 1,884 Online
