Nacra rudder Tendons
Maybe steer less?
To actually answer the question, APS has rope core universals http:/
No reason you should have broke any after 1 season of sailing. I sailed my infusion for 2 years (including a tybee) with no issues. Maybe there is something going on with the angle of the tiller on the F16? If Kirk can lay off the Coors Light for a minute he might be able to tell you what you're doing wrong.
If you really wanted a rope in it, it wouldn't be that hard to put one in yourself, but it would probably weaken the
tendon
more. There is definitely nothing on the market of the right diameter with a rope in it.
How much of the rubber is showing between the tiller cross bar and the rudder arm? If there is to little it will put to much stress on the rubber piece. You may have to cut some off the rudder arm or tiller cross bar to make them fit right. I have had to do that on a few boats to get the rudders aligned right. Also pre drilling a hole before you put the screw in helps.
I second what Dave says. You should see at least an inch of the rubber piece between the rudder arm and the cross bar. If you don't see that much, you need to shorten your crossbar and realign the rudders. Properly setup, you should get multiple seasons out of those tendons (I've got about 5 on my F18).
I guess he is a little disappointed in his dealer if he set the boat up wrong. The quality control on Nacra is slim to non. Every boat I have gotten from them has had some kind of issues. When you spend 20,000 on a boat you really don't expect to have to get out the hack saw and dremel.
I think he's down there in the land of Captain Kirk @ Key Sailing...that should be a pretty easy part to get from them.
If the ahpc boats aren't set up by a dealer, there would be a grocery list of issues. Probably true of all of them, when you know what needs to be double checked, trimmed, or whatever its no big deal. Things get over looked as well. Sh!t happens, and people can get disgruntled for some strange reasons too.
I've had four Vipers from new. Only one hit the water with zero issues, and I spent two solid days building that boat.
I think Kirk would not even know how to sail if you took the Silver Bullet from him. It's sad he can do so well in that condition against the rest of us (being sober).
Broken rubbers are no laughing matter. Alot of you guys Dad's will attest to that.
On that note, I never broke one on the N-20 and only changed them out once in the twelve years that I had it. That was also doing ALOT of mileage in distance races.
You've gotten the right advice, but if you want to re-invent the thing ,go for it.
The tendons are pretty stiff and do not feel very rubbery in your hands. I agree that there is an error in the set-up of your boat. We all know Nacras QC wasn't there for you already.
- 301 Online
