why not use a blue "wal-mart" tarp
WHY?
Is it the flogging that can occur, the fact they only last a year or 2, or other reason?
They're not terribly good with UV exposure...In a cover situation, that's usually what does them in.
That is really the only thing you should ask of a cover is UV protection.
Having made 10 covers or so, the main thing is making them easy to put on (so you actually put it on) and making it so it doesn't flap AT ALL. Even a blue tarp should last you a long time if it doesn't flap.
WHY?
For a sail or for a cover?
Haha.. i meant as a cover..
but u got me thinking - and wouldn't ya know...
I have found the key to keeping it from flogging is to add more grommets and tie offs.
I made one out of a $30 tarp treated for UV protection, added more grommet holes and it has lasted two years so far. Easy to put on, but harder to secure due to all the ties at each grommet. I also coated the boat-facing side of the grommets to keep them from scratching the boat.
WHY?
They could use a little more draft
it is a sailrite lsz-1 that has paid for itself about 5 times over (would have paid for itself 10 times over if I actually charged captain cardiac for all the covers I made for him!)
Small problem with the tabs of webbing is that they degrade too, and might go faster than the cloth, but even the smallest webbing is way stronger than it needs to be so some loss of strength due to UV is fine.
WHY?
I like the bowsprit
As mentioned, the more ties, the better. I used bungees, and even using just the supplied grommets, was able to reduce most of the flogging.
Up here, the snow was the real killer. They would rip from the weight of the snow well before flogging or UV became a problem.
Mike
thanks for the input everyone.
So it seems to me there is no real good reason not to use them if a. properly secured b. snow isn't an issue and c. that ugly blue mono needs battens (and Dacron sails)
I have been using 1 or 2 very large tarps for years with no real issues, besides they degrade.
I just wanted to see if there were any reasons I hadn't thought of, or any
war stories
of death and explosions from tarps
Maybe 1 day I will get a machine and make some real covers.
Be real careful of water pooling. If the tarp is too loose, it will start a puddle and that puddle will continue to grow until your mast is bent like a toothpick. Whenever I use a tarp to cover a boat, I cut a few drainage holes in it so it can't collect excess water.
Custom hull covers are definitely the way to go if you can do it. They'll keep the hulls in pristine shape and it's like unwrapping a present every time you go sailing.
How well a blue tarp will work as a cover, depends on where you live and where you store your boat. I live in Houston. In my back yard, a blue tarp will last about a year. In the boatyard, it will last about 2-3 months in the summer. The boatyard has no shade and is the middle of the largest concentration of petrochem plants in the world.
Don't go by the color of a coated polypropylene tarp. Look at the thickness or the weight. The thinness I remember was 2.3 mil and the thickest was a 15 mil white one from Australia(it lasted almost 2 years). I messed up last year, I grabbed a silver/back tarp on sale. I was halfway through making a cover when I checked the package and found it was only 4 mils. That cover lasted until July.
This year I am trying something different. When my my cover feel apart last year, I whined and complained finally said
those yellow Naugahyde rudder covers and storage bags are 25 years old and have been in direct sun for at least 15 years
The yellow Naugahyde cover for the A-Class has been working great for the last month. The rest of the material came in Tuesday, so I will start on the Wave cover and a mast cover for the A.
I will let you know how Naugahyde works. The bottom is open so I shouldn't have any condensation issues. It's waterproof and with the cover fitted to slip over the bows and sterns, it only needs 4 ties. It's just too heavy to move.
Sunbrella works great, though it obviously won't be as durable as naugahyde (which i think is vinyl). I use something called weathermax which I got off e-bay (was labelled on e-bay as Surlast, which it clearly isn't) and it works well also even though it is lighter than sunbrella. You do have to pick the correct color sunbrella though. Seems as though none of the colors really work as well as their standard pacific blue in terms of showing dirt, etc
I get 3-4 years out of Sunbrella and getting ready to order some when I saw the same yellow Naugahyde used for my rudder covers on eBay for $5/yd. I figured at that price it was worth an experiment.
Years ago somebody made black Naugahyde Hobie 16 covers for trailering. They seemed to last forever and nobody mentioned a mildew problem. One person mentioned, they dried the hulls out nicely. Then again, in the direct summer sun here, they were too hot to touch.
Conversation inspired me to go to the lake and check the Blue Tarp on the H14. I painstakingly added extra grommets, made a little tent over the tramp with two scraps sticks of pvc conduit (mast/s hang in garage), tied it off way low between the hulls so the snow would slide off. Been bitterly cold, plenty of snow, hadn't checked on it in over a month...it's TOAST, ripped right down the seam.
I bought a tramp cover that was touted to be
as good as
sunbrella...looked just like it. It disintegrated in three years, $50/year mistake <img src="<>/sick.gif" alt="sick" title="sick" height="15" width="15" />
Remember the Billboard vinyl thread? Got my Vespa scooter sign for free. Made a cover for the H20, worked great, heavy material with UV coating on lettering side, bugger to put on and off.
IIRC that full size Billboard weighed 120 to 160 pounds, took two of us to load in my trunk.
Have half the billboard left, time to dig it out and make individual hull and tramp covers this time.
For me it is the cost/work/longevity ratio ....
I stopped using the
blue poly
tarps since I thought they just look
hokie
when I cover my H18Mag on it's trailer in the back yard (w/ the wings folded up)... so I've been using either brown or silver tarps. I get 3-4 years out of a tarp .... I use 3/8
bungie or doubled 3/16
bungie (old trap bungies) to hold the tarp in place.
The tarps cost approx $25/ea .... and the re-used
old trap bungies
are free since I include those in the cost (in my mind) in my racing budget of boat parts/maintenance.
For my P19 I have from Murrey's a Nitryl Polyvinyl Cover ... and that cover has lasted 6-8yrs so far and is still going strong .... except this year it has snowed before I got my lazy procrastinating butt in gear to put it on the boat for the winter after I brought the P19 home from the YC in December. The cover for the P19 is used all year long most years .... as I haven't been sailing her too much in recent years since I haven't been doing any open class handicapped
distance races
(ie: point to point) which is what I used her for the most. (But last year she sat down at the YC w/ the
mast up
all summer after the
Down the River Race
....) So we'll have see just how much longer the Nitryl Cover lasts .....
So we'll have to see how these covers comparitively cost out ...
I would like to get a custom boat cover for my TheMightyHobie18 ... but the cost-benefit ratio seems to lean to the cheap tarp and I haven't found a manufacture of a sunbrella custom boat cover that doesn't cost lots of $$$$$.
Harry
H18Mag/P19MX
How many poor Nauga's have to die for your precious cover? Nauga's have made a strong comeback in the wild, since fine Corinthian leather is now being used in most automobiles. This onset of Naugahyde boat covers may set the recovery back many, many years. Oh the humanity!!!!
per the Naugahyde website
Q: With all the cruelty in the world, how can you kill those cute little Naugas just for their hydes?
A: We don't. Naugas shed their hydes without harm to themselves, making Naugahyde the Cruelty-Free Fabric. For more information and pictures about Naugas, their history and their habits, read the Nauga Story
- 4,548 Online
