First time on the trapeze...
I bought a used harness off of the Beachcats classifieds recently. Same model and size as the one I got with my supercat. We took turns trapezing from the crew position and elected to skip trying to helm at the same time. Great fun. We went to Geneva Lake in Wisconsin. Much bigger than Rock Cut. Adam did manage to pitch pole us again and we only broke a bungee. We also managed to right the boat from the turtle position so that is a confidence booster.
Unfortunately the port hull was very crunchy sounding when we were walking on it during righting. I'm in the market for another hull. This was the one I did a soft spot repair on.
Video to follow.
shortyfox wrote: Once you get the SC17 going you can say goodbye to pitch poling.
I feel that with the pitch pole skills we are developing, we could find a way!
Here is the video:
Took a few tries to learn the timing on grabbing the dolphin striker to keep the boat from flipping over the other way. But we have a lot more confidence now.
In the video you can see Adam lose his footing, and fling off the back while orbiting me via the trap wire. Great fun. What a great day it was.
FWIW, I've had old H16s with hulls that were somewhat "crunchy" on the sides but never failed....not as critical as having solid decks. Hard to tell in the vid, but when sailing that far off a stiff breeze, it's important to get weight back as far as possible.....crew should be trapped out behind/straddling the skipper. Also, it looks like the jib sheet is unattended most of the time. Crew should keep it in hand and always be ready to play/uncleat it.....especially off the wind. Holding the jib sheet can also help crew stabilize against getting knocked backward while being bounced around out there. Looks like y'all did a good job unturtling....weight on leeward aft corner. When righting, in addition to releasing sheets and travelers, the boat should be pointed pretty much into the wind to help avoid it going over in the other direction or trying to sail away. It's a bit of a balancing act, but in most conditions that can be accomplished by getting weight way forward, burying the bow, and having the wind blow the stern downwind like a weather vane.
Glad you're having so much fun....you certainly put the work in to earn it!
Edited by rattlenhum on Sep 27, 2021 - 07:25 AM.
Thanks again all for the feedback. I've shared it with my son as well. I was about as far back by the skipper as my meager trapeze skills allowed - Not sure if I was straddling him but right next to him. We will try again.
Definitely good to know about the crunch hulls.
- 346 K Posts
- 1,665 Online
- 31.2 K Members
