Install access hatch on Hobie Wave?
(@jjpanozzo)
[#7183]
My Wave (like others) has access ports which are underneath the seat pads making it virtually impossible to use. I was at my local dealer the other day and wondered if I can install a Hobie Twist n Seal hatch, that is typically intended for their kayaks, in place of the existing ones.
Has anyone done this? Does it work? Any help/advice would be appreciated
Take Care
Joey P
rolexjoe@gmail.com
Posted : July 10, 2019 9:02 am
Where would you put them? Is the problem with the existing ones that you are sitting on them so they are hard to access?
Posted : July 10, 2019 9:51 am
(@jjpanozzo)
Damon. The problem is that they lie under the seat pads which are held down with adhesive. To get access to the hatch, you have to ruin the seat pad ($30 each) to get to it. I am thinking if I can install an easier hatch, I can trim the seat pad to expose the hatch and thus gain easier access
Posted : July 10, 2019 10:01 am
(@tradisrad)
My Wave had access ports towards the rear of the hulls on the flat area behind the cross bar. They were simple 8 or 9" ports with twist on lids. I no longer have the Wave and can't find a pic to share. Yes, you can add them!
The access ports under the seat are screwed and glued on and as I recall I could barely get my hand in there.
Posted : July 10, 2019 10:20 am
I asked hobie dealer Kirk Newkirk (KeySailing.com) about this and he said the deck ports used to be standard on the Waves and the best spot to add them is behind the rear beam.
So tradisrad probably had one that came stock with the ports.
Posted : July 10, 2019 11:26 am
