No more water in the hulls
General Sailor Talk
1
Posts
1
Users
0
Reactions
1,872
Views
I had a small crack under the daggerboard pit. I did a temporary repair from the outside that lasted a few days, then thought to repair it from the inside and threw epoxy all around the pit bottom, with a plastic cup and a brush. I did it both sides. After sailing the hulls came out almost dry, like never seen.. Yes, it’s about time to do a bottom job, but last time I did it I still had more water after sailing. I’m sure it’s a common problem but not such a common solution, so I thought to share. Just put the cup with epoxy inside the hull first (through the inspection port) and then apply.
Posted : April 18, 2022 1:54 am
Forum Information
- 346 K Posts
- 1,670 Online
- 31.2 K Members
Our newest member: Preston John Fradet
Latest Post: Mystere 6.0 refit project!
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
