Righting a SuperCat20
7 Users
(@windyb)
[#8511]
I've had 3 SC20s and have yet to see a single video or hear from someone that has actually righted a 20 using the righting system.
Would love to hear from anyone regarding this challenging process.
Posted : October 21, 2024 1:58 pm
Rob Hangen
(@rch701)
Are these the ones that use hyfield levers on the shrouds? I have always wondered how the heck they climbed up to reach the release on one of those.
Posted : October 22, 2024 4:46 am
 SC19
(@sc19)
Which step in process is causing the issue? Climb up the tramp, pull the pin, open the lever then pull the second pin if needed.
Bill Roberts claimed to right an RC27 solo.
Posted : October 22, 2024 5:44 am
(@bradinjax)
I added hyfield levers to my Stiletto 27 after consulting with Tom Haberman @ ARC. I have never had to use the levers solo but for practice I used the main halyard to pull the boat over in shallow water to test the righting process.
You only have to do the upper lever. As mentioned above, pull the pin and activate the lever to release the stay tension on the upper shroud. My boat was well balanced at this point and just a little weight on the end of the centerboard righted her very quickly. I have righted H16s and H18s hundreds of times. Righting a 1200lb 27 foot beach cat using hyfield levers was easier.
I have seen a video of a Dragonfly getting righted using hyfield levers as well as a Gougeon 32. I will try to find them.
Brad in Jax
2x Stiletto 27s (one for sale soon)
Edited by bradinjax on Oct 22, 2024 - 06:00 PM.
Posted : October 22, 2024 11:58 am
(@charlescarlis)
They are like magic. Righted a Hobie 21 with them. But the extension cable broke. That was my fault for using to thin a wire for the extension. Had a rigger make me some dyneema shroud extensions.
Posted : October 22, 2024 1:43 pm
(@tamumpower)
How the heck do you reach the lever. If the boat is on its side you can’t reach the shroud from the bottom hull. Not even on an 8ft wide boat. If you try and climb the tramp you are going to pull the boat full turtle.
Posted : October 22, 2024 4:07 pm
Rob Hangen
(@rch701)
+1
Posted : October 23, 2024 3:46 am
(@lakewateree)
I had to use them once on one of my SC20's. You have to climb the boat to get to the upper shroud. Once up there I pulled the pin and the hull dropped some. I don't remember, but don't think I even released the levers, it was quite windy. Once down the boat easily came over. Once back on the tramp, we parked it and reattached. Climbing up to the shroud was the hard part
Posted : October 24, 2024 6:37 am
 SC19
(@sc19)
Supercats don't turtle.
Posted : October 24, 2024 9:28 am
(@charlescarlis)
I ended up climbing up the dolphin striker and releasing real quick. Never even started to turtle, felt stable.
Posted : October 25, 2024 4:01 pm
