Rolling Sails
Hi All,
I have been told that sails should always be rolled so that the foot of the sail is on the outside of the roll which is opposite of the way I prefer to roll them.
To me, it is easier to start rolling at the foot and keep rolling as I let down the sail. If I were to roll the sail the recommended method, I would have to fan fold the sail on the tramp and then start rolling from the head. Since I have laminated sails, I have been told never to bend the material so that it creases. IMHO, man handling the sails twice increases the likelyhood of a crease being formed.
Does anyone know the reason you have to roll the sail opposite from how its raised? Does it make any difference in the life of the sails? Anyone have any tips on sail rolling they can share?
Thanks in advance!
the window will die anyway.. they have a limited life span and are very UV sensative. my last one cost me $65 to get replaced at Doyle sails... not a big factor to me.
laminant sails will delam... just a fact. rolling them works them as well. but of course hard creases are worst
to roll from the bottom is actually pretty rough on the windows cause they get crinkeled a lot in the process (unless you have crew) helping roll the clew
rolling top down will put less curl in the foot of your sail (memory from being stowed that way) giving you slightly more sail area.. but is really not a factor unless you are a pro racer looking for every square centemiter of sail area
The reason Hobie says to roll your sails from the top down is, normally the botom panels will be wet or damp from sailing and if you roll from the bottom up you will trap the moisture to the inner most part of the roll. Which is never a good thing. They suggest that you start from the head and fold over to the 2nd or 3rd batten and start to roll making sure that the battens are inline. A loose roll is better that a tight roll so the sail can have a little air flow betwen sailing trips.
The easy road is rarely ever the right road. If you are not a racing sailor, I doubt that it matters which way that you roll your sails. I do rinse my sails every 4th or 5th time I use them. I sail in the Atlantic and the salt crystals and sand can play havoc with the threads. The important thing is that you just go sailing as often as you can, and help your fellow sailor when they need it.
- 1,789 Online
