Spinnaker/snuffer cover?
Hi, new to cats. I sail from home (boat is on a lift) and I'm wondering what people do with their spinnaker and snuffer bag when done? Do you remove them both from the boat or leave them? I typically sail a few times per week. If you leave either of them on, is it worth getting some kind of bag to protect the somewhat expensive snuffer bag? What do you use ... perhaps a mainsail cover??
Several of us sewed up our own covers out of sunbrella like fabric and use velcro to fasten around the snuffer bag. Some of us remove the spinnaker and others who sail often leave the spinnaker in the snuffer. I see that New England Catamarans sells a Nacra midpole suncover.
Thanks for the info, that's helpful. Unfortunately I don't have any sewing skills! Good to know that someone makes a cover, but I find it a bit expensive. Amazon has mainsail covers much for much less (under $35) and it looks to me like they might fit ... has anyone tried?
I remove the spinnaker itself each time and roll up the snuffer bag into itself for which I have a cover for.
https://www.h2o-sensations.com/en/spinnaker-poles-accessories/2670-nacra-17-snuffer-bag-race-class-legal-suitable-f18--8215000725569.html.
Though I might need to invest into the full spinnaker snuffer cover so that I can leave it all attached when done as it takes at least an extra 15 min just to deal with rigging the spinnaker.
However, if you leave it on the lift, I would worry about it getting the spinnaker wet. Mine is sleeping on the beach 🙂
My lift it puts the snuffer well clear of the water (I'd say normally at least 3') and the prevailing winds mean we normally do not see much in the way of waves. I can also normally put the spinnaker up to dry for a while on the lift before tucking it away in the snuffer (again, prevailing wind is offshore and we are in a fairly sheltered little bay, so the spinnaker is not flapping wildly).
ght wrote: My lift it puts the snuffer well clear of the water (I'd say normally at least 3') and the prevailing winds mean we normally do not see much in the way of waves. I can also normally put the spinnaker up to dry for a while on the lift before tucking it away in the snuffer (again, prevailing wind is offshore and we are in a fairly sheltered little bay, so the spinnaker is not flapping wildly).
Slope Unblocked
It's very good
So thought I'd post back ... I did end up buying the $30 mainsail cover from Amazon. It fits surprisingly well, with the wider part that was designed to attach to the mast being used at the snuffer ring end. It doesn't take long to install it either (mostly velcro attachments).
- 346 K Posts
- 1,833 Online
- 31.2 K Members
