What Winter Projects Do You Have?
DamonLinkous wrote: [quote=presto99]Hobie 18: Replace both hulls. Fix rudders, clean up daggers. Paint
Both hulls? What happend!
Apparently my theory on the colored hulls not failing was wrong.
We were sailing in a distance race on October 1. Wind was 18-20 and gusty, bay was choppy. We almost capsized (75~80 degrees of heel) with 470 lbs of crew.
7 miles out, on a broad reach, the boat was slowing down, handling funny and then tried to pitchpole. We dumped the jib, no effect, dumped main, bow came back up slowly. My crew (dad) and I looked at each other and said at the same time "the port hull is full of water". We tried to tack back to the beach but the leeward hull was still filling, and killed our momentum, so I gybed, it was a little busy in the back office, and I managed to slow the boom down by letting the main sheet hit my life jacket. Didn't hurt, and kept some stress off the rig. That put the flooded hull to windward, and we stayed on the leeward side of the boat, sailed for an hour, and made it back.
When we got to the beach, I popped the inspection port and saw that we had about 3 inches of air space left in the hull. The boat was still in water, but I pulled the plug to get some weight off so we could get wheels under it. The flow of water blew the plug out of my hand, and off the tether. 45 minutes to drain hull after we got it on the beach.
Took boat home rinsed it off, then inspected boat found cracks in both hulls at forward beam, port hull had crack at aft beam and in top of dagger trunk. We also had some delamination, behind daggers. We were going to beef up the forward beam, fix delamination, paint boat, and perform IRAN this winter.
Found two white hulls from an '88 on CL for a decent price, bought them, sold my hulls to a guy building an electric boat(????) so now I am going to fix forward beams, some cosmetic issues, and rebuild.
pirateboy dont paint your hulls in my experience painting is the lazy way out and youre just going to have to repaint every other year or so or more if u like beaching the cat or use it alot! heres the solution and it will save you some cash! go to your closest major fiberglass supplier ie. not west marine their is distributors all over or go online to fiberglassflorida.com and order from their but anyway get 1 gallon of polyester gelcoat white of course not the tooling. then 1 gallon of durtatec clear high gloss additive mix these 2 together equal parts 1:1 if you want a diffrent color than pure white mix in the pigment now you can usually get it all in the same place you buy your gelcoats and resins anyway back to the project once everything is mixed 1:1 go buy a cheap vertical drop spray gun from harbor freight or discount auto 15 bucks is usually what they cost. now sand the boat down nice and smooth fill in cracks and make repairs as needed once done wipe boat with acetone and clean rag. now mix up a batch of the 1:1 mix with your catalyst use a measuring device dont eye ball it youll probably end up kicking the gelcoat to fast and ruin you spray gun if you eye ball the measurments. now spray your hull nice and neat any runs sand down and do 4 or 5 coats. of this or more if u want each gallon will do 100sq ft so 2 gallons which you will have will do 200sq ft more than any beach cat by about 8x . now once you got your coats done sand out inperfections do touch up and go sail !!! the gallon of gelcoat will be 40bucks the duratec about 90 the spray gun 15 plus cups ect probably around 200 bucks and youll do it the right way if you got questions call me i do fiberglass for a living! email and ill send you my number if needed zachhansman89@yahoo.com
zachhansman89 wrote: pirateboy dont paint your hulls in my experience painting is the lazy way out and youre just going to have to repaint every other year or so or more if u like beaching the cat or use it alot! heres the solution and it will save you some cash! go to your closest major fiberglass supplier ie. not west marine their is distributors all over or go online to fiberglassflorida.com and order from their but anyway get 1 gallon of polyester gelcoat white of course not the tooling. then 1 gallon of durtatec clear high gloss additive mix these 2 together equal parts 1:1 if you want a diffrent color than pure white mix in the pigment now you can usually get it all in the same place you buy your gelcoats and resins anyway back to the project once everything is mixed 1:1 go buy a cheap vertical drop spray gun from harbor freight or discount auto 15 bucks is usually what they cost. now sand the boat down nice and smooth fill in cracks and make repairs as needed once done wipe boat with acetone and clean rag. now mix up a batch of the 1:1 mix with your catalyst use a measuring device dont eye ball it youll probably end up kicking the gelcoat to fast and ruin you spray gun if you eye ball the measurments. now spray your hull nice and neat any runs sand down and do 4 or 5 coats. of this or more if u want each gallon will do 100sq ft so 2 gallons which you will have will do 200sq ft more than any beach cat by about 8x . now once you got your coats done sand out inperfections do touch up and go sail !!! the gallon of gelcoat will be 40bucks the duratec about 90 the spray gun 15 plus cups ect probably around 200 bucks and youll do it the right way if you got questions call me i do fiberglass for a living! email and ill send you my number if needed zachhansman89@yahoo.com
PUNCTUATE!
I am going to blend two H17s. Many of the parts I want to keep are on the hulls that need to be structurally corrected. I have two very solid hulls that need a bottom job, just a bit too many beach scratches. I want to do the gel coat on the bottoms only. There are not many scratches on the sides. I am also concerned about weight. I am hoping to apply new gelcoat to the bottoms and about 6 inches up each side of each hull. I will try to mask and then blend the new gel up the sides. zachhansman89 gives good advise on spraying the whole bottom of the hulls. Do you think it makes since to do just the bottoms and a little up the sides? It is extra work with masking and blending the spray. But then I don't need to prep the entire bottom and sides.
Also looking at new wing tramps and main sheet.
H17 x2
I bought new sails for the P18, should have them in January. I will hold them in my lap lovingly, stroking them with abandon, waiting for April.
I am on my third 1980s era boat, and these are my first new sails ever. Square tops too. I crawled away from Hobie 16s in previous years, hope I can smoke them now. Woohoo.
klozhald wrote: [quote=uh]Also getting new sails. For my P19.
Local sailloft (mariner-sails) is thrilled that they get to build something cool instead of typical white monohull sails.
Mine will be (mostly) dark blue on the top and bottom, with a white, red, white panels in the middle. Inspired by the letter C:
Edited by kgatesman on Dec 14, 2011 - 05:55 PM.
1. trying to figure out how to make my 30 year old gelcoat on the hobie 16 i have owned for 25 years to shine.
2. flat tire on trailer
3. one of the rudder cams needs replacing
the fun to cost ratio for this boat has been incredible. i imagine at some time i will get something faster, after my youngest loses interest, i know i can still rig and sail this one by myself.
banana yellow with orange crush sail.
oh and i have a couple of monohulls i need to have ready by the spring, a laser and a banshee.
I'm posting this up just for the satisfaction of coming back in May and adding "Done" next to all of this. I was given a "free" P16 that is in pretty good shape but sat under a tree and tarp since 1995. So here is my extensive list of reviving a classic.
Hulls
Delam both sides rear x member to rudders
Keels epoxy and glass
topside / side gouges fill and fare
One deep nick silver dollar size - epoxy from outside add glass from the inside since I can reach it
Replace Inspection ports
Paint or Gel Coat- I want to keep it powder blue so still thinking
replace plugs
Sails / Tramp - Already at sailmaker
Jib -new zipper
Main/Jib restitch pin hole repair
Tramp / Patch
Battens repair or replace cracked ones. I'm leaning towards replacing the longest and cutting down the rest.
Rigging
Standing - order new
Running - Order new- Sta-Set + Salsa Main sheet ( still thinking on this one) + main Halyard wire
Traps - New wire / shock cord / blocks
Tramp lace kit
Hawaiian Righting system + bag
Blocks
Mashead Sheves - Replaced
Main / jib clean and lube
Spars & Cross Members
water test for leaks
replace nylon ball joint
replace mast cleat
re-rivit traveler to x member
Re-tighten / Check / Adjust Dolphin striker
Rudders
Fare a few nicks
Paint
Replace Port casting
Re-reg up down lines / replace sheves
free up SS pintles in Aluminum gudgeons
tiller extension - home brew for now
Trailer
Sand / repaint
Rewire
Repack/ replace bearings
Mast caddy / Mast Crutch Fix/ repaint - Done
DMV
Register / Insure
Other odds and ends
Rescue knife(s)
waterproof blue tooth speakers. Keep the droid in the hulls and tunes on the tramp.
Trap Harness - Maybe by the end of the season
Plus everything else I forgot.
April / May is going to be a marathon to get this all done by Memorial Day, but I got my wetsuit ready to roll and 4 months to plan and prepare. I see the most major task as being the hulls, specifically painting - I really wish I had a garage.
Needless to say I've got a spreadsheet running with all my needed parts / measurements and a growing pile of parts in the basement.
Sail at Christmas-day, its around 8 degrees Celsius overhere.
Install my new Go Pro HD Hero2 on the cat, ( it's a Christmasgift from my wife, discovered it to early) .
Train as long the weather permits us, have a new sailmate and we want to do the round Texel-race this
summer. We both have dry-suits.
RE-install the 4-way jibsheet arrangement on the P18-2.
Sort out the rules in the texelyardstick about having a spi on a P18-2.
If so, arrange the blocks and snuffer on the cat.
Sort out how to put photo's in a post at the beachcat forum,
witch I will try right now;
Regards, André
- 31.7 K Topics
- 346 K Posts
- 985 Online
- 31.2 K Members
Guess I'll have to break out the Foxpro and the coyote rifle...what....you think I'm going to sit here and watch sailing videos all winter???
