Got it up for the first time, and without viagra! lol, The sheet that is......but, need help!
I need a bit of help with the three pulleys I have. There's a large one with a cleat on it attached to the back of the boat at deck level, there's also a small pulley hooked to that one. Then I have a large pulley, I think hooks to the bottom of my boom. There are three places to hook pulleys under the boom, but it looks like I only have one. Can someone snap me a picture of this pulley set up, with the lines run? Or, draw me a picture how I rig the lines in the pulleys. Oh, I also have a pully on port and starbord sides of the deck by my feet, and 2 smaller one's up forward which I'm sure is for the jib, but, also, how does the boom line run through the two deck pulleys? Sorry for the novel. John 😕
This is 2 on stern of boat............
This goes on bottom of boom, (I think)\
These are on both sides of deck by the kick boards. I think the outside set are for the jib, but how to rig inside pair???????????? Or are they for the jib also? 😕
edited by: cougarmarkIV, Jul 21, 2009 - 05:37 PM
Is the one on the stern sit in front of some sort of track with a traveler car that can run back and forth across it?
I would guess the side is for a Jib but not sure about the inner one does it have some sort of cleating mechanism.
I would love one of these old boats for good family cruiser. Especially for the early part of the season when the water is so cold.
The stern large pulley has no track around it, but also has a cleat, see picture
Yes the inner pulley one has a cleat, it is shown in picture.
They guy I bought it from has 1 more he said it was actually in a little better shape(mine needed paint on deck. I bought mine on ebay for $850.00 with trailer, and he knocked off $50.00 because I had to paint her, (paint was $86.00 a gallon though. 🙄 )
He said he's sell the other boat even cheaper, and it's been in a storage locker. Clear Lake, IA.
edited by: cougarmarkIV, Jul 21, 2009 - 05:59 PM
Looks like a 4 part mainsheet like H-14. Pull mainsheet out all together. Now go thru big pulley with cleat (bottom), up to rear pulley on boom, down to small pulley on main Harken, up to 2nd pulley on boom (that you don't have), down to big Harken & tie off on becket above small pulley. Now to Jib. You need two small pulleys & snap hook (oval) on jib clew. Lay jib sheet on deck. Now go thru cleat with white block, then black block (pulley), now to small block (pulley) on jib clew, then back to black block and tie off on what looks like a becket (or tie off place). Take other end of jib sheet & do same on other side. Black block slides on track. More forward pulls more on leach (trailing edge) of jib. More aft pulls more on foot of jib. Pete
pbegle wrote: Looks like a 4 part mainsheet like H-14. Pull mainsheet out all together. Now go thru big pulley with cleat (bottom), up to rear pulley on boom, down to small pulley on main Harken, up to 2nd pulley on boom (that you don't have), down to big Harken & tie off on becket above small pulley. Now to Jib. You need two small pulleys & snap hook (oval) on jib clew. Lay jib sheet on deck. Now go thru cleat with white block, then black block (pulley), now to small block (pulley) on jib clew, then back to black block and tie off on what looks like a becket (or tie off place). Take other end of jib sheet & do same on other side. Black block slides on track. More forward pulls more on leach (trailing edge) of jib. More aft pulls more on foot of jib. Pete
I confess, I'm no artist. This is how I understand your post Pete, but not sure if I'm starting right at the bottom at the cleat, and where to end it(star). Sorry for the crappy drawing......... 🙁
Sooo, I tie off where I have the star in drawing on top of small pulley, is this correct? If so, then, I have a problem, cause there is nowhere to tie off on that pulley, so, I guess I need 2 more pulleys like the single one in my center pic then? Is that correct?
edited by: cougarmarkIV, Jul 21, 2009 - 07:05 PM
The blocks in your top photo are attached to the boat, large end down. The blocks in the middle photo attach to the boom, large end up. Start at the becket ( where the line is tied now) and go down to the small block, then back up to the small sheave that is just above the becket ( where the line is tied now ). Come down to the same sheave in the bottom block ( small sheave in the ratcheting fiddle block ). Then go back up to the large sheave in the top block ( fiddle block ) back down to the large sheave in the bottom block and out the cleat. This will be 5 to 1.
edited by: skarr1, Jul 21, 2009 - 08:01 PM
skarr1 wrote: The blocks in your top photo are attached to the boat, large end down. The blocks in the middle photo attach to the boom, large end up. Start at the becket ( where the line is tied now) and go down to the small block, then back up to the small sheave that is just above the becket ( where the line is tied now ). Come down to the same sheave in the bottom block ( small sheave in the ratcheting fiddle block ). Then go back up to the large sheave in the top block ( fiddle block ) back down to the large sheave in the bottom block and out the cleat. This will be 5 to 1.
Okay, thanks, but, I still need one more block for the boom right?
Nevermind!I'm an idiot, I just realized there were to sheaves in eack of the large blocks! DaUgh 😕 🙄
edited by: cougarmarkIV, Jul 21, 2009 - 08:02 PM
OK, John in this photo ( I think you have seen it before ) the top block is attached at one place on the boom
Follow the lines for your jib setup.
Looks like they go from the jib to the block on the track, then to the block on the swivel and out the cleat.
edited by: skarr1, Jul 21, 2009 - 08:51 PM
The photos are here.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120422824276&viewitem=
edited by: skarr1, Jul 22, 2009 - 05:50 PM
skarr1 wrote: The photos are here.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120422824276&viewitem= edited by: skarr1, Jul 22, 2009 - 05:50 PM
That is MY boat, I'm sue1959snow, I won it. lol 😀
- 2,909 Online
