Access Port Locatio...
Access Port Location
ctcataman
(@ctcataman)
[#7054]
I am going to put access ports in the Nacra to keep an eye on the internals. Putting it equidistant between the side stay anchors and cross beam would allow access to both without over stressing either region.
Too bad previous owner put one right next to side stays on the other side. I may glass it closed and put in symmetric ports.
Stern ports will go midway between transom and beam for sale reason.
Posted : April 25, 2019 8:36 am
(@cholley12)
He might have put that port there to replace the shroud
Posted : April 25, 2019 12:01 pm
ctcataman
(@ctcataman)
That makes sense.
Posted : April 25, 2019 4:30 pm
Andres Chianale
(@Andinista)
ctcataman wrote: I am going to put access ports in the Nacra to keep an eye on the internals. Putting it equidistant between the side stay anchors and cross beam would allow access to both without over stressing either region.
If you find something after the inspection, the meaning of “access” will change to being able to reach with one hand. I would rather choose one side or the other. I personally wouldn’t put an inspection port just to be able to look inside without suspecting of a real issue. If something is taking away your sleep, i’d Start from there.
Other approach could be benchmarking: what’s more common around, either from factory or added for repair.
Or if it’s about a general inspection, consider that it shouldn’t be necessary often, maybe once or twice in boat’s life and that’s it. Therefore removing the hull cover might be more appropriate, inspect thoroughly, repair and buy good sleep for next 10 years.
Anyhow, the location you suggest doesn’t seem quite useful to me, you won’t be able to see a lot anyway, unless you put a camera inside. About modifying the other side for symmetry, not worth it! Your brain will filter it out quickly, and potential future buyers will notice either the repair or the asymmetry, I don’t see the former improving their buying decision.
Edited by Andinista on Apr 26, 2019 - 08:37 AM.
Posted : April 26, 2019 2:31 am
"I personally wouldn’t put an inspection port just to be able to look inside without suspecting of a real issue"
+1
If you must see inside for your sanity - i would create a small opening and put a gopro in there and take video
then repair it and re-gel coat it . (or just use the current ports - throw a light source in there and then use your phone / gopro
Edited by MN3 on Apr 26, 2019 - 10:58 AM.
Posted : April 26, 2019 3:45 am
(@hullflyer)
which model nacre
dagger boards ?
Posted : April 26, 2019 4:24 am
ctcataman
(@ctcataman)
5.0, no boards
Posted : April 27, 2019 12:08 am
