Cartopping hulls
ctcataman
(@ctcataman)
[#7029]
Occasionally the need to car top a hull or two arises. A hitch mounted canoe carrier is great for aft support but too narrow for two hulls. Solution, unbolt 16 or 18 inch top cross bar and swap in a piece of unistrut. Bolt tight and voila, another anchor point. This is on a Caravan btw.
No elegant front anchor system discovered yet. Just way too much plastic to deal with.
Posted : April 6, 2019 4:34 pm
(@gahamby)
Can you install a front hitch receiver?
Posted : April 7, 2019 4:26 am
(@Anonymous 945)
For front anchor, raise the hood and tie a loop of rope around hood hinge. Now you have anchor points forward for a rope. Pete
Posted : April 7, 2019 4:27 am
best be careful and check your local laws
there are federal and state laws that restrict the amount of overhang you have
I have moved hulls before - i took the cat off my trailer and used it ti move hulls
same with a mast
Posted : April 8, 2019 2:33 am
