composite mast for solcat 18?
Hi,
Traded my old boat for a solcat 18. Thinking about adding a composite mast. Anyone know the specifications of the standard aluminum mast(cross section width,length and wall thickness) so I can compare stiffness and mechanical properties?
Thanks !!!
Didn't realiize the Nacra 20 has a carbon mast. Have a link for details? Just an idea at this stage. Talking with Innovative Composite Engineering to see if it is possible by stacking 2 lower sections of an I14 rig on top of each other. Told them the rig needs to be stiff and still has to be reasonable $. We'll see 🙂
Ref http://www.innovativecomposite.com/ & http://www.biekerboats.com/Bieker_Boats/Int_14_Skiffs.html
Cheers!
You may want to think before spending that kind of coin on a very old and very heavy boat. The cost of a new stick for a nacra 6.0 (aluminum) is close to $4000 a carbon stick would be very high (even more)I would think and what would be the advantage over the stock mast?
Here is a thread at SA that may interest you
http://forums.sailinganarchy.com/index.php?s=53789b0e549134d82d6fd3aade8d52c4&showtopic=123957
Edited by just.sail on Jul 06, 2011 - 02:20 PM.
Thanks for the sa reference. Agree, old boat and heavy. $4k-yikes, no way. Price has to be much less. Its old right? Advantages: less weight. Should give the boat a new personality. Less weight aloft, easier to right, easier to step mast(I'm old too :-)). Also will probably remove 2 ft from mast and square the top of the main. Have to see what the $ are. Just an idea. Thanks again!
- 1,781 Online
