Concrete on the bottom of hulls
I purchased a boat from a dealer that rents cats at the beach, and to protect the hulls, the dealer put a protective material on the bottom of the hulls. I would like to take it off.
It is medium dark grey, and hard as rock. Any ideas as to what this stuff is? and any ideas on how to safely remove it?
Thanks!
It might be epoxy and aluminum powder.There could be Kevlar fabric on there. Epoxy will soften with heat. Get a variable temperature heat gun and a putty knife. Start at a low temperature. I've done this to an H14 without trashing the original gel coat. Don't get impatient with the heat!
You'll end up with hulls in need of refinishing. Is the current surface that ugly? You're in for a lot of sanding one way or another. Will the current surface not sand out? I take it the dealer doesn't know what's on there. Keep us posted, GH
I think I would have asked the dealer about it before buying the boat....
Spray on truck bed liner?
Grey Marine Tex?
You could try hitting it with a sanding disc or belt grinder and see if it comes off. Or you might just be better off leaving it alone. If it isn't slowing the boat down much, it might be worth keeping there.
Edited by Dogboy on Jan 04, 2016 - 01:09 PM.
I spoke to the dealer (Ocean Motion) and they stated it is Iron-crete from Mantek.
They also stated it might chip off. They have had some of this stuff fall off.
I suppose I need to be prepared to restore the bottom finish when I get this stuff removed.
It runs the length of the portion of the hull that typically sits on the beach, to protect against damage from dragging on the beach - a long length. I can sand it down some, and smooth it out if not remove it completely. I will probably have to do this next winter when I have a garage. Or I could buy an F16.
Here is a reply to an inquiry to Mantek:
Iron Crete is an epoxy which is identical (exept for color) to the epoxy resin which is mixed with glass fibers to form fiberglass.
Any chemical that will remove our product would damage the fiberglass, and a temperture high enough to soften it would also damage the resins in the fiberglass.
Sanding or grinding are your only good options. The product can be sanded or ground when fully cured.
Edited by yelkenli1 on Jan 06, 2016 - 07:55 PM.
Removing the cured resin (aka concrete) is not really necessary, another solution is to add MORE filler on both sides and fair in a new profile for the bottom. Wet sanding will yield a nice fast profile that is also a great protective "bottom job." "Fairing in" is much easier and less damaging than removal in many cases.
- 718 Online
