hobie 16 halyard wire replacement
Technical Help
3
Posts
3
Users
0
Reactions
2,851
Views
IIRC the replacement halyards (from Murrays, at least) have a small loop and no thimble on the end opposite the sail that will easily go through without taking anything apart. That end is only loaded while raising the sail (until the nicopress is locked in the hook), so it doesn't need to be big or heavy duty.
Posted : April 26, 2012 6:11 am
Forum Information
- 1,790 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
