Hobie 16 mast has water
I posted this over at Hobie. Please let me know if you have any thoughts
http://www.hobiecat.com/forums/viewtopic.php?f=14&t=55330
Thanks!
If you think you have a leak, this plug with sealant stuffed in both ends of the mast is very effective:
http://www.murrays.com/50-20060000.html
I don't have any recommendations for the leak other than the standard submerge, look for bubbles, drain, and seal procedures.....lots of threads on the Hobie forums in that regard. I'd seriously doubt the water has caused any internal corrosion issue. May be obvious, but, for trailering, I always flip the mast so that the luff track is up. If the mast crutch padding is inadequate, the rubbing can cause damage to the aluminum part of the track (happened to me). This way there's a lot less stress on the plastic portion of the luff track on the comp tip as well.
I carry my mast track-down. The trailer crutch has rubber pads which support the sides in a sort of V configuration, and at the rear I use the Hobie thingy which doesn't seem to put any pressure on the track. I want the track down so the tie-down straps don't push on it.,
- 568 Online
