Nacra 5.2 zipper problems
Technical Help
4
Posts
3
Users
0
Reactions
2,255
Views
no worries at all.. go to any canvas / bimini shop (or find one online) and get a new zipper car. usually a plastic #3 will work fine (on all the jib zippers i have seen). if you want to, get a metal one as well. the cost should be about $1.50 total.
with the plastic one, you should be able to force it onto the correct side. if not, carefully remove 1 tooth from the correct side with needle nose pliers.
i have gone through several zipper cars in my sailing career. no big deal at all.
Posted : June 15, 2010 7:30 am
Forum Information
- 346 K Posts
- 1,658 Online
- 31.2 K Members
Our newest member: Preston John Fradet
Latest Post: Mystere 6.0 refit project!
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
