Prindle 16 bridle plate
I have not seen a P16's but I have seen a very clever N5.2's , nothing more than a piece of stainless rectangle in shape about four and half by three inches folded lengthways at same angle as the hull to the deck corner then in the middle a tab is cut and bent where a hole is drilled for the pin . The tab width is the same with as the existing tab . The "L ''one piece shape is placed so that the cut tab is pushed through the bridle slot so that the now outwardly bent tab connects with vertical of the piece against the hull.
Good luck
Posted : March 12, 2014 12:42 pm
Forum Information
- 1,861 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
